Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
"unable to load public key" error on openssl1.1.1f
keiji_niwa
Hi all
I try to perform encryption using the public key obtained using eHSM-KMS getpublickey API.
However, in my environment, the encryption fails with "unable to load Public key". my environment using openssl1.1.1f.
Encryption succeeds in other environments. This environment uses openssl3.0.2.
What causes encryption to fail with an "unable to load public key" error in openssl1.1.1f environment?
keiji_niwa
keiji_niwa
This is a correction.
pkcs#11 is wrong
The correct name is pkcs#8.
Iffa_Intel
could you clarify if there is a specific reason you are using OpenSSL 1.1.1?
Cordially,
Iffa
keiji_niwa
eHSM-KMS supports OpenSSL1.1.1.
eHSM-KMS in our environment also uses OpenSSL1.1.1.
Therefore, we decided to use OpenSSL1.1.1 for encryption.
thank you.
keiji_niwa
hi all.
I was able to resolve the issue by changing the public key format to pkck#11.
thank you.
keiji_niwa
pkcs#11 is wrong
Sahira_Intel
I recommend opening a ticket in the official EHSM Github: https://github.com/intel/ehsm/issues
Sincerely,
Sahira
