Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 Discussions
sgx application runtime error for can not find .so lib
Kirin_Young
I had successfully build a sgx application which called "test" and its gcc code is "gcc test.cpp -L. -lmyso". The libmyso.so(-lmyso) was created by makefile and I counld find it in current directory. But when I used "./test" to run the application, it faild with the error "can not open/find the shared library libmyso.so". So stranger! What should I do to run the app?
My platform is Ubuntu16.04, SGX SDK and PSW are installed sucessfully. But I am not sure intel ME is installed in my computer, is it related to this?
Scott_R_Intel
You may need to add your current app path to the library path.  For example, to do this temporarily while running your app (notice the . at the end to indicate current directory):
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:. ./test
FYI:  https://serverfault.com/questions/279068/cant-find-so-in-the-same-directory-as-the-executable
Regards.
Scott
Scott_R_Intel
Regards.
Scott
Spisak-Spisacki__Krz
There is a good article about this: https://www.cprogramming.com/tutorial/shared-libraries-linux-gcc.html
In short: use either $LD_LIBRARY_PATH or rpath. Both solutions have upsides and downsides, as explained in linked article.
Kirin_Young
Thank you for all your responses. I learned a lot and solve my problems.
