Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
sgx_ecc256_create_key_pair fail
AArya2
I've written a very simple test to learn working with elliptic curve cryptography inside an enclave. But the key creation method fails with SGX_ERROR_UNEXPECTED.
Here is my enclave:
#include "Enc_t.h"
#include "sgx_trts.h"
#include "sgx_tcrypto.h"
int Test(sgx_status_t *error)
	sgx_ecc_state_handle_t handle;
	sgx_ec256_private_t sk;
	sgx_ec256_public_t pk;
	sgx_status_t status;
	status = sgx_ecc256_open_context(&handle);
	if (status)
		*error = status;
		return 1;
	status = sgx_ecc256_create_key_pair(&sk, &pk, &handle);
	if (status)
		*error = status;
		return 2;
	*error = SGX_SUCCESS;
	return 0;
and this is my host app:
#include "Enc_u.h"
#include "sgx_urts.h"
#include <cstdio>
#include <tchar.h>
#define ENC _T("../Debug/Enc.signed.dll")
int main()
	sgx_status_t error;
	sgx_enclave_id_t eid;
	sgx_launch_token_t token;
	int updated = 0;
	int step;
	error = sgx_create_enclave(ENC, SGX_DEBUG_FLAG, &token, &updated, &eid, nullptr);
	if (error)
		printf("Failed to create enclave\n");
	Test(eid, &step, &error);
	if (error)
		printf("Failed on step %d\n", step);
	return 0;
The result is error = 1 on step = 2.
Any ideas what I'm doing wrong or what I might have configured incorrectly? I'm using Visual Studio Community 2015 and Intel C++ Compiler 17.0.
Surenthar_S_Intel
use the below statement instead of this "status = sgx_ecc256_create_key_pair(&sk, &pk, &handle);"
  • status = sgx_ecc256_create_key_pair(&sk, &pk, handle);
-Surenthar
Surenthar_S_Intel
-Surenthar
AArya2
It worked. Thank you!
larguet__ramzi
hi Arya P,
I am very happy that it worked for you.
Could you please, Arya P, share the EDL file of  the Test() function, because I have a problem in thedeclaration of this function in my EDL file.
Thank you
larguet__ramzi
hi,
How could I get the public key  created by the function sgx_ecc256_create_key_pair out of the enclave?
