Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1560 Discussions
sgx_foreshadow_issue remote_attestation_issue
du__xin
We are facing the following issue even with the updated cpu microcode and Ubuntu 16.04 kernel.
Errors:
---- Enclave Trust Status from Service Provider ----------------------------
Enclave NOT TRUSTED
---- Platform Update Required ----------------------------------------------
The following Platform Update(s) are required to bring this
platform's Trusted Computing Base (TCB) back into compliance:
 * The CPU Microcode needs to be updated.  Contact your OEM for a platform
   BIOS Update.
The following mitigation solutions have been attempted. But still failed with above errors
Based on the microcode reference: https://www.intel.com/content/dam/www/public/us/en/documents/sa00115-microcode-update-guidance.pdf
dmesg | grep 'microcode'
[    0.000000] microcode: microcode updated early to revision 0x96, date = 2018-05-02
[    1.224122] microcode: sig=0x906ea, pf=0x20, revision=0x96
[    1.224898] microcode: Microcode Update Driver: v2.2.
Based on Ubuntu kernel update reference.
https://wiki.ubuntu.com/SecurityTeam/KnowledgeBase/L1TF
cat /sys/devices/system/cpu/vulnerabilities/l1tf
Mitigation: PTE Inversion
Ubuntu kernel information.
dpkg -l | grep linux-image
linux-image-4.15.0-32-generic              4.15.0-32.35~16.04.1 amd64        Signed kernel image generic
Scott_R_Intel
Hello.
What version of the BIOS are you using?  The latest I see on Dell's website explicitly calls out the uCode fix for SA-115, though it appears you probably have the correct version.
Ver. 1.2.1
Fixes & Enhancements
Enhancements:
1. Updated CPU microcode to address security advisory Intel Security Advisory INTEL-SA-00115 (CVE-2018-3639 & CVE-2018-3640)
2. CPU performance and thermal behavior.
https://www.dell.com/support/home/us/en/19/drivers/driversdetails?driverId=C1HPN
Regards.
Scott
Scott_R_Intel
Hello.
Which platform/motherboard and CPU are you getting this message on? Also, which PSW version are you using?
Regards.
Scott
du__xin
Scott R. (Intel) wrote:
Hello.
Regards.
Scott
Sorry I missed that
Base Board Information
  • Manufacturer: Alienware
  • Product Name: Alienware 15 R4
  • Version: A00
  • Serial Number: .91C9PN2.CN1296384701A9.
  • Asset Tag:
  • Features:
  • Board is a hosting board
  • Board is replaceable
  • Location In Chassis: *
  • Chassis Handle: 0x0003
  • Type: Motherboard
  • Contained Object Handles: 0
CPU model name : Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
PSW installed: ​sgx_linux_x64_psw_2.2.100.45311.bin
Scott_R_Intel
Hello.
Ver. 1.2.1
Enhancements:
Regards.
Scott
