Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
sgx_init_quote
muye
When I install the sgx devlopment environment with the latest packages for remote attestation , sgx_init_quote  always returns 1, how can i correct it?
ubuntu@sgx:    modinfo isgx
filename: /lib/modules/5.0.0-23-generic/kernel/drivers/intel/sgx/isgx.ko
license: Dual BSD/GPL
version: 2.11.0
author: Jarkko Sakkinen <[email protected]>
description: Intel SGX Driver
srcversion: 87784B58E0AACD186EEF5B6
alias: acpi*:INT0E0C:*
depends:
retpoline: Y
vermagic: 5.0.0-23-generic SMP mod_unload
ubuntu@sgx:       apt list --installed | grep sgx
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libsgx-ae-epid/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-ae-le/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-ae-pce/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-ae-qe3/unknown,now 1.9.100.3-bionic1 amd64 [installed,automatic]
libsgx-aesm-ecdsa-plugin/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-aesm-epid-plugin/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-aesm-launch-plugin/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-aesm-pce-plugin/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-aesm-quote-ex-plugin/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-enclave-common/unknown,now 2.12.100.3-bionic1 amd64 [installed]
libsgx-epid/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-headers/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-launch/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
libsgx-pce-logic/unknown,now 1.9.100.3-bionic1 amd64 [installed,automatic]
libsgx-qe3-logic/unknown,now 1.9.100.3-bionic1 amd64 [installed,automatic]
libsgx-quote-ex/unknown,now 2.12.100.3-bionic1 amd64 [installed]
libsgx-quote-ex-dev/unknown,now 2.12.100.3-bionic1 amd64 [installed]
libsgx-uae-service/unknown,now 2.12.100.3-bionic1 amd64 [installed]
libsgx-urts/unknown,now 2.12.100.3-bionic1 amd64 [installed]
sgx-aesm-service/unknown,now 2.12.100.3-bionic1 amd64 [installed,automatic]
muye
It's very kind of you for you replay again. I   have fixed it.
Steps are as follows:     Uninstall SGX PSW  ,disable SGX in BIOS ,reboot, enable SGX,reinstall PSW.
Sincerely,
muye
muye
when i make my own RA, sgx_init_quote    returns  1.
JesusG_Intel
Hello muye,
Did you try running the RemoteAttestation sample in the SGX SDK?
Sincerely,
Jesus G.
Intel Customer Support
muye
Infact ,I did my attestation and get the result GROUP_OUT_OF_DATE form IAS.  After I updated the newest  BIOS,  compiling is ok,but sgx_init_quote always returns 1 when running . Then removing all and reinstall sgx development environment does not help.
JesusG_Intel
Hello Muye,
After upgrading your BIOS, did you ensure that SGX is enabled? Execute cpuid | grep -i sgx
Sincerely,
Jesus G.
muye
Thank you for your replaying.   After executing    cpuid | grep -i sgx   ,it shows it is normal .
SGX: Software Guard Extensions supported = true
SGX_LC: SGX launch config supported = false
SGX capability (0x12/0):
SGX1 supported = true
SGX2 supported = false
SGX attributes (0x12/1):
muye
Sincerely,
muye
