Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1540 Discussions
what's the Maximum of "StackMaxSize"and "HeapMaxSize"in Enclave Configuration File(.xml)?
dai_c_
 hello,recently,I want to pass amounts of data from application to enclave at once.and I notice that enclave will firstly copy those data from application memory to the enclave memory(enclave stack).It may cause enclave can't have enough stack space to do other things,so I want to change the "StackMaxSize"and  "HeapMaxSize" for more space,but I don't know the maximum of those,I just know that the value of the "StackMaxSize"and  "HeapMaxSize"  Must be 4KB aligned.so any one can tell me about the maximum of "StackMaxSize"and  "HeapMaxSize"in enclave configuration file(.xml)?Thank you very much!
Hoang_N_Intel
There is a related posting on this topic https://software.intel.com/en-us/forums/intel-software-guard-extensions-intel-sgx/topic/670322
Basically, it must be 4KB aligned (see our documentation at https://software.intel.com/en-us/node/708992) and the total should be less than 90M for optimal performance. On Linux, it can be swapped out. Therefore, the number can be as large as the operating system can support.
Performance should be taken into consideration. Our documentation states "To avoid wasting the valuable protected memory resource, you can properly adjust the StackMaxSize and HeapMaxSize by using the measurement tool sgx_emmt" so you should define large number with care. There is also a whitepaper on this performance issue at https://software.intel.com/sites/default/files/managed/09/37/Intel-SGX-Performance-Considerations.pdf
dai_c_
ok,Thank you , and I really appreciate your help.
