Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
314 Discussions
Can not connect to AI PC instance with ssh
RWirt1
Initally without using ssh I was able to attach and upload some files to build models and necessary data files.  I have been unable to connect since then using ssh.  My time is expiring so need to connect.
Dayang_Intel
Hi RWirt1,
We have also received your private ticket. Is it related to the same issue? If it is, we will proceed to close this thread. We are currently working on this issue and will get back to you as soon as possible through the private ticket.
Dayang
RWirt1
You can close this issue.  The system was rebooted and then I could connect, but the system would hung and I could not connect.  I was given a second system to try and it works fine. I've run 3 days on it and it works ok. Connection is not a problem with it.
Dayang_Intel
Hi RWirt1,
Thank you for your confirmation. This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Dayang
