Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
328 Discussions
Instance required a dkms kernel update, can't connect after update
twg-developer-1
After the upgrade to *-122 (attempting to setup SR-IOV), the box hasn't returned to service and there seems no console access to review or fix a boot issue after kernel update.  I'll need help fixing my instance.
[Connection]
ssh -Y -X -J guest@146.152.226.75 devcloud@192.168.6.2
[Last Commands Before Reboot]
sudo docker build $(env | grep -E '(_proxy=|_PROXY)' | sed 's/^/--build-arg /') --file docker/ubuntu22.04/dkms/Dockerfil
e --tag dkms .
sudo apt-get install linux-headers-$(uname -r) linux-image-unsigned-$(uname -r)
sudo apt-get install linux-headers-5.15.0-122 linux-image-unsigned-5.15.0-122
[Log: Partial]
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.15.0-122-generic
Found initrd image: /boot/initrd.img-5.15.0-122-generic
Found linux image: /boot/vmlinuz-5.15.0-119-generic
Found initrd image: /boot/initrd.img-5.15.0-119-generic
Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings ...
done
Aznie_Intel
Hi twg-developer-1,
We apologize for the inconvenience that you are experiencing. To ensure we can assist you effectively, please provide the following details. If not applicable, please use 'N/A'. We appreciate your cooperation, and we look forward to resolving this matter promptly.
1. Severity level of the issue: Low/Medium/High/Critical
2. Reservation details:-
- Instance type:
- Instance ID/Resource ID:
- Start time/Created at:
- Instance IP address:
- Region: us-region-1/us-region-2
3. Cloud account ID:
4. Is there any important data stored on the instance? Yes/No
5. Can the IDC support team access the instance and perform the required operations to validate or fix an issue if needed? Yes/No
6. Screenshots of the error encountered when connecting on JupyterLab and SSH.
7. Contact details: I have sent you a private message requesting this information. Kindly check your Messages under your profile icon in the top right corner.
Aznie
Aznie_Intel
Hi twg-developer-1,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
