Intel® Unison™ App
Support for the Intel® Unison™ App, a Multi-Device Experience software product that allows users to connect their devices and collaborate between them.
158 Discussions
Extending the desktop
mrjojujo
Intel® Unison™ 을 설치 하고 내 아이패드에서 확장된 디스플레이를 이용하고 싶은데 인텔 유니슨 애플리케이션 추가 드라이버를 다운로드를 해도 확장 디스플레이 문구가 나타나지 않음
laptop: 삼성 갤럭시 북 프로5
CPU: intel Ultra 7 258V
window 11
ram 32
ssd 1tb
ipad: 아이패드 프로 6세대 12.9
ios: 18.1.1
DhannielM_Intel
Hello mrjojujo,
영어로만 지원해 드릴 수 있습니다. 이 응답을 번역하기 위해 웹 번역 도구를 사용했기 때문에 일부 부정확한 번역이 있을 수 있습니다
Thank you for posting in the community, as I have check your laptop to Samsung Website. It appears that your laptop is Evo Certified which qualifies for the premium features for the the Intel Unison. To have an Extended Display feature using the Intel Unison please Follow these steps below:
Step 1: To install Intel® Unison™ Extended Display
If Extended Display icon cannot be found in Intel® Unison™ PC App, install the enhancement package (it is mandatory for Premium feature) by download from Intel® Unison™ app additional driver
Or Extended display > Show me how > Download package.
1] Extract downloaded file
2] Right click Certificate.cer and Install certificate.
Select Local Machine → Place all certificates in the following store -> Trusted Root Certification Authorities → Finish.
3] Right click UnisonIddDriver.inf > Install.
4] Double-click on the executable file – IntelUnisonDriverSetup
5] After success installed and IDD service will be run as background process in Task Manager
Step 2: To enable/disable Intel® Unison™ Extended Display feature
  1. Click Extended Display icon.
  2. Switch ON/OFF for Extended display
  3. Click Display Settings, it will prompt out Did you mean to switch apps?
  4. Click Yes > it will open Windows* Display settings
To check on an Error message of Cannot connect.
For the best performance of Extended Display feature usage, check below steps:
  1. Connected PC and tablet are best with the same network environment.
  2. Intel® Unison™ PC App on the connected tablet is open and visible. Switching to another app on the tablet may disconnect the feature. User may minimize the Intel® Unison™ PC App on the PC but closing it will disconnect the Extended display feature.
  3. By default, the Extended display is position to the right of the primary display.
  4. The Extended display supported an extended mode, duplicate mode, or single screen only. It also integrates with Windows* multi-display settings. To adjust the Windows* display, click Windows > Start > Settings > System > Display or click Display Settings
  5. When switched to duplicate mode, popups might be silenced due to Windows* focus assist/DND (Do Not Disturb) mode.
  6. If PC on sleep mode, hibernate or connected device encounter connection lost, the extended display session is stopped and the Extend display icon will be turned off.
Please be inform that extended display feature will be turn on again once PC return from sleep mode, hibernate or connection are available on both devices. Additionally, please make sure that your wireless driver are updated to the latest version based on your laptop manufacturers driver version. As such please follow these steps and if you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dhanniel M.
