Intel® Unison™ App
Support for the Intel® Unison™ App, a Multi-Device Experience software product that allows users to connect their devices and collaborate between them.
157 Discussions
Intel Unison Stopped Supporting APK Files
Nicconike
Until recently the sharing of apk files have been stopped. After the latest update in Microsoft store for intel unison, if you try to send an apk file it prompts an error saying it's not supported. But, prior to this latest update it used to work , I was able to send apk files previously. I don't know why Intel has done this kinda bad.
Labels (3)
DeividA_Intel
Hello Nicconike,
Thank you for posting on the Intel® communities. I understand that you have some issues sending APK files with the Intel® Unison™ app.
As part of the process, I would like to confirm the following first:
1. Did the app come Pre-Installed?
2. What is the operating system version and build?
3. What is the unison PC App version?
4. What is the iPhone model+ iOS version or Android phone and Android version, and mobile Unison app version?
5. What is the Computer Brand, model, and Intel Processor?
6. What is the intel Wi-Fi & Bluetooth adapter model used and version?
7. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
Deivid A.
Nicconike
Hi, I understand your question is regarding Intel Unison, if my system falls under the mentioned requirements for selected processors or generations, etc but it was already working perfectly fine for me before updating it in Microsoft store (that's what I'm suspecting if changed the behaviour)
Nevertheless, below are your question's answers:
1. No
2. Win 11 - Build 22631
3. Intel Unison Version u:20.16.4909.0/c:20.16.6423.0
4. Android Version 11 - App Version 20.16.4828 (Already updated to latest)
5. MSI GL65 10SEK - i7 10750H
6. Intel(R) Wi-Fi 6 AX201 160MHz - 22.250.1.2 & Bluetooth - 22.250.0.2
DeividA_Intel
Hello Nicconike,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello Nicconike,
Thanks for your time, In this case, to be able to continue with the investigation I will require the report from the Intel® System Support Utility (Intel® SSU). Please run the tool and attach the report to your next response.
Thanks for your comprehension.
Deivid A.
Nicconike
Well, this is overcollection of data as the troubleshooting was needed from the backend team of this app or the QA team. Anyway, support team won't proceed without their provided instructions, so I have attached the file
DeividA_Intel
Hello Nicconike,
I am sorry to know that this process seems annoying and unnecessary. This file will help me to have a better view of your system.
I will continue with the investigation and I will get back to you as soon as possible.
Deivid A.
Nicconike
Thanks for the heads-up.
Waiting for the quick resolution of this issue.
DeividA_Intel
Hello Nicconike,
Thanks for your patience. I would like to let you know that based on the test performed, using the Android Unison app send 1 APK file to the PC Unison App and from PC Unison App > File Transfer > Android mobile >Add files. There were no issues, blocks, or error message prompts using the same Wi-Fi internet connection for both PC and Android phones.
Can you inform me at which step the error "Unsupported file type. Please use the file transfer" appears? Also, can you capture a video for me when using the Unison PC App and screenshot from the Unison Android App?
Deivid A.
Nicconike
I am attaching the video evidence which shows the prompted error when trying to send an apk file from PC to phone. I also tried by using the other method of selecting the files by clicking on "Add Files" , still same error. But am able to send the apk file from phone to PC (tried again just now) and not the other way around.
DeividA_Intel
Hello Nicconike,
Thanks for the response. Thanks for the video and the additional details about the issue, this will help me with the investigation. As soon as I have information I will let you know.
Deivid A.
DeividA_Intel
Hello Nicconike,
Thanks for your time. I want to let you know that due to security concerns, transferring some of the executable file formats will be controlled by the latest revision soon. I do appreciate your feedback.
If you have any questions, please let me know.
Deivid A.
Nicconike
Thanks for the response. As per your reply does it mean that the dev team is working on fixing this issue and deploy a new patch for it right? If so, then that would be great. Hoping for a quick update coming to intel unison. This will help everyone who might need it!
DeividA_Intel
Hello Nicconike,
In this case, the development team is making improvements to the Intel® Unison™ app and your feedback has been taken under consideration. However, there is no ETA (Estimated Time of Arrival) for any future updates.
My last recommendation is to keep your system up to date to receive the latest features for the Intel® Unison™ app.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Intel Customer Support
romisabaki45
It’s true—after a recent Intel Unison update, sending APK files is no longer supported, even though it worked before. Intel has quietly discontinued full functionality: Unison is officially discontinued as of June 2025, and the team behind it has been shut down. Only limited use remains on a few Lenovo Aura PCs through 2025—but APK transfer is no longer available on most systems.
harie
Intel Unison no longer supports APK sideloading, but you can still use it effectively by relying on its main features like file transfer, notifications, calls, and messages. If you need an APK on your phone, just install it directly on the device and then manage or share files through Unison. This way, you can keep using Unison smoothly without issues.
