Intel® Unison™ App
Support for the Intel® Unison™ App, a Multi-Device Experience software product that allows users to connect their devices and collaborate between them.
photo editor
frandoer
can i change the default photo editor when i click open
VonM_Intel
Hi, frandoer.
Thank you for posting in our Intel communities.
Intel® Unison™ App allows for swift and convenient access to your phone or tablet's photo gallery, enabling you to organize, remove, and transfer your desired photos straight to your computer. You may refer to this link: Intel Unison App, for more information. As such, could you please clarify what you mean about changing the default photo editor when you click to open?
Moreover, I do not have sufficient details about your hardware and software configuration to help you. Please run the SSU report so I can check important details such as OS build#, Graphics, wireless driver versions, errors logged in the system, etc).
Looking forward to your response. Have a nice day ahead!
Von M.
VonM_Intel
Hi, frandoer.
Von M.
frandoer
thank you. I found the solution: change the default editor in Windows 11
VonM_Intel
Hi, frandoer.
I hope you are doing fine.
Kindly let us know if you still need assistance.
Von M.
frandoer
I changed Windows default editor and that did the trick
thank you
VonM_Intel
Hi, frandoer.
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel.
Von M.
pix12434
Yes, you can change the default photo editor on your device. Here's how you can do it on different platforms:
  1. Windows: Go to Settings > Apps > Default apps. Scroll down to "Photo viewer" and select the app you want to use as the default photo editor.
  2. Mac: Right-click on any image file and select "Get Info." In the "Open with" section, choose the desired photo editor from the dropdown menu, then click "Change All."
  3. Android: Go to Settings > Apps > Default apps > Default apps selection. Choose the category "Opening links" and select your preferred photo editor.
  4. iOS: Unfortunately, iOS does not allow you to change the default photo editor system-wide. However, you can open images directly in your preferred editing app and make edits from there.
