5186 Discussions
Неработоспособность intel raid controller rs2wc040 на Windows 10 x64
MRyav
При попытке установить драйвер на Windows 10, контроллер не может работать корректно с ошибкой "код 10". Драйвер указывался вручную, однако ни единый драйвер из файла диска не подошёл. На 32 разрядных ОС драйвер устанавливается и работает. Прошивка последняя доступная на сайте интел. Какое может быть решение данной проблемы? Драйвер официально поддерживает Win 10 любой разрядности.
SergioS_Intel
Hello MRyav , Thank you for contacting Intel Customer Support. Can you please provide us with the driver version and name that you are trying to install? Additionally are you able to access the RAID BIOS by hitting the Ctrl + G keys? Please do not hesitate to contact us again if you need further assistance. Best regards, Sergio S. Intel Customer Support Technician Under Contract to Intel Corporation
MRyav
Yes. Everything works as it supposed to work, I have even created array with two 6TB drives. But only before OS launched. x86 OS's work with this controller good, driver installation is succeeded on Win2003 x86, Win 10 x86. Today I tried to install this controller on Win Server 2016 and situation is similar to Win 10 x64 - not able to run device with driver. Driver is installed, but it cannot run(Code 10). I tried Driver versions 7.708.12.00, 6.703.03.00 and 6.713.05.00. None of these was able to run the device on x64 OS
MRyav
Update. Win SRV 2012 R2 has the same problem. Problem 0xA in log
MRyav
Update. Win 7 x64 is not able to run device as well, but x86 OS ran it properly
Franklin_S_Intel
Hello MRyav, When a driver install occurs the error message usually also contains a "FailReasonString" that can provide more details on the actual reason why the install failed. Could you check on that and let us know what it says? Regards, Franklin S. Intel Customer Support Technician Under Contract to Intel Corporation
Franklin_S_Intel
Hello MRyav, Where you able to check to see more details on the cause of failure during the driver install? Regards, Franklin S. Intel Customer Support Technician Under Contract to Intel Corporation
NAlam2
An email list is a list of email addresses. When a message is required to send to the list of email address, normally an corespondent service will be used. This is a convenient way of online communication because you will not need to type in all the email addresses if you want to send a message. Most businesses use these lists of email to notify consumers about products and services as well as promotions like discounts and freebies. One of the advantages of using email lists is that you can easily distribute your messages to people regardless of the number of email list. If you want to use this tool to communicate with consumers, here are 3 little known building an email list tips.
The first secret to building an email list is gathering the email addresses to where you will send your messages. Email list can be "opt in" or not. With opt in email list, the future recipient of your emails opted to receive them. They may have clicked a subscribe button or signed up to receive your emails in your website. However, you can also get emails of consumers and surprise them with your emails.
download.jpgNevertheless, you need to put an option for receivers to not receive or unsubscribe your emails. The opt in method is better than sending emails to people who are not even interested to your products and services. If you choose the second type of email list, you have to look for email addresses of possible clients. There are services that will provide you with email addresses of people in your chosen market. If you will opt to pay for the entries on your email list, make sure to think about your target audience to ensure that your money will not go to waste.
Franklin_S_Intel
Hello MRyav, Please let us know if you still need any assistance. Thank you. Regards, Franklin S. Intel Customer Support Technician Under Contract to Intel Corporation
Franklin_S_Intel
Hello Michael, As an additional note. The 64bit drivers for Win10 are located at: Intel_Windows_drv_MR_7.708.12.00_pv\RAID\win10_x64 So, make sure he is pointing to this folder directly and not the root of the folder, sometimes Windows gets picky with that. Regards, Franklin S. Intel Customer Support Technician Under Contract to Intel Corporation
Franklin_S_Intel
Hello Michael, I am just checking to see if you have any other questions or concerns. Regards, Franklin S. Intel Customer Support Technician Under Contract to Intel Corporation
Franklin_S_Intel
Hello Michael, Do you need any more assistance with your issue? Regards, Franklin S. Intel Customer Support Technician Under Contract to Intel Corporation
