5173 Discussions
Another GPU for server motherboard.
IFiks
I have P4304CR2LFJN (with W2600CR2 board). This board contains only slow matrox GPU. I tried to insert GTX 660, but I was not able to use this videocard for video output and CUDA calculations. Is this server board can use only proffesional cards (for example, Quadro). Any advices?
AChan85
What error message did you get?
IFiks
There is no error. Simple, monitor has no video signal from nonnative GPU.
David_A_Intel
Which PCIe Slot are you using, and how many processors do you have installed? The reason I asked is that some PCIe slots are routed through the second processor.
Go ahead and update the BIOS to the most recent version https://downloadcenter.intel.com/download/24614/Intel-Server-Board-S2600IP-and-Intel-Workstation-Board-W2600CR-Firmware-Update-Package-for-Extensible-Firmware-Interface-EFI- 02.04.0003 if you are able to get video through the onboard solution.
Feel free to add a summary or screenshot of the video settings in BIOS.
IFiks
My apologize for late answer.
David, thank you. The problem solved when I've changed this setting parameter.
David_A_Intel
Could you provide us with more detail information about the error or the failure when using this video card?
It is true that we have not validated that video card with our system. Intel always recommends using validated components to avoid unforeseen issues.
