Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
BHS-SP BSDL requirement
Santos_Chen
We need to confirm which BSDL the following CPUs should use.
6505P SRVU7
6521P SRVNS
870208_Xeon_6700_6500_HCC_4UPI_8CDDR_88LPCIe_rev05.bsdl
With 6505P > length Mismatch Expected:2748 , Actual:2566
869758_Xeon_6700_6500_LCC_3UPI_8CDDR_88LPCIe_rev06.bsdl
With 6505P > syntax error
During test with interconnect or Pull up / Pull down will auto power off.
Vik3
Hello Santos_Chen,
Greetings from Intel!
Thank you for posting on Intel Community.
The Content you are looking for is available in our Resource and Documentation Center. You may search the document with the content ID 834609,834608.
Please note that this content requires a privileged access to Intel's RDC and if you do not have the privileged access, please follow the article - How to Apply for an Intel® Resource and Documentation Center (RDC) and/or Intel® Developer Zone (Intel® DevZone) Account.
Thank you for using Intel products and services.
Vikas_Intel
Santos_Chen
6505P SRVU7 is 3Die
834609 & 834608 BSDL is 4 Die , Therefore, it cannot be used!
MACM
Hi Santos_Chen,
Thank you for the response,
We request you to please create a ticket with Intel Premier Support.
Please find the link below.
 IPS URL: https://premiersupport.intel.com
Mohammed Ali CM
