BIOS-Update for S3000AHLX
udole77
初学者
1,839 次查看
i have server with cpu intel xeon 3210 and mainboard is called s3000ahlx
I think the name S3000AH also refers to S3000AHLX by intel. This is the BIOS-Update program:
https://downloadcenter.intel.com/de/download/16926/Intel-Sever-Board-S3000AH-BIOS-Firmware-Update-Configuration-Utilities-for-Linux-Windows-WinPE-
I am getting the error flashupdt.cfg not found. I really don't know where to find and get it. I tried everything like installing flashupdt und setting up syscfg.
in english: https://downloadcenter.intel.com/en/download/16926/Intel-Sever-Board-S3000AH-BIOS-Firmware-Update-Configuration-Utilities-for-Linux-Windows-WinPE-
this is by far the most complex bios-update i have ever seen. had to read 2 manuals, usually it's just a click. or a file to load in the bios, or something for FreeDOS.
0 项奖励
4 回复数
udole77
初学者
1,827 次查看
awesome i found the bios update for intel s3000ah or s3000ahlx, it has somehow something to with sr1530ah bios ... i don't really understand it however i found this page
https://www.helpdrivers.com/servers/Intel/Intel_Server_Boards/Server_Board_S3000AH/
and learn that the file name is s3000ah_bios_r54.zip
googled it and et voila
https://www.google.com/search?client=firefox-b-d&q=s3000ah_bios_r54.zip
https://rebyte.me/de/intel/1504/file-4376/
shame on you intel. stop producing wasteful garbage and support it forever, it's just 4 megabytes!!!
0 项奖励
AlHill
超级用户
1,822 次查看
Be very careful with those 3rd party driver sites.   you never know what payload the packages you download are carrying.
0 项奖励
udole77
初学者
1,818 次查看
Yes, of course! But I don't mind really. It's an old mainboard with old CPU Xeon 3120 2x2 GB DDR2 RAM, not even DDR3. Whatever I watch on xvideos the hacker has to watch too.
It's just, I got sad when I learned that CPU's and mainboards can't be recycled. From then on I said, whoever gives even totally exotic PC's or servers to me, I update the hell out of every part, even the firmware of the CD-DVD-drive and put everything inside a computer needs (total capacity of RAM, a nice graphic card, an SSD with minimum 120 GB for operating system, 20 € now (sep 2020, no dram needed, only cheap stuff), I install Windows 10 on it and maybe Linux Mint, I check for updates once a month) I also low-level-format any data on hard disks and make them swap for Windows and Linux. sometimes I need a S-ATA to IDE Adapter for 8 €. It's a great gadget. You can connect any SSD or any drive with S-ATA to the IDE-port on the mainboard. It's way cheaper than using an SSD with IDE-port on it.
It's like a hobby and I feel good about it.
0 项奖励
udole77
初学者
1,815 次查看
btw it has these slots:
Intel Adaptive Slot 6 (can be used as PCIe x8 easily but difficult in PCIe x16)
PCI-X
PCIe x4 (i can put a pcie x1 graphic card but the are expensive and the pcie x16 graphic cards are cheaper and have more power)
PCI
PCI
how can i use the first slot intel adaptive slot 6 as pcie x16. wth so many slots why? totally propietary pcie x16 is the best!
where can i find graphic card for pci-x?
0 项奖励
回复
