5173 Discussions
Booting from IDA 2.5.1 hangs on S5000PAL
skuma77
Hi All,
I am trying to update the BIOS on my S5000PAL board and i have created a CD for IDA 2.5.1 Version and when i try to boot the machine from the CD it shows the Initial Screen where it shows the IDA Initialization screen and then it hangs.
I tried booting multiple times with no luck..
When i removed the CD and booted from the hard drive it worked fine. I don't think booting from the CD did any damage..
Any suggestions pls...
mars
Daniel_O_Intel
You can try removing add-in cards and disconnecting the backplane, or just try the DOS update instead.
