5182 Discussions
Component Unfit for every Server blade on mfsys25
TGeil
all of the sudden the Modular Server Control shows for both blades that are installed "Component unfit". I have reinserted both blades allready and restarted the whole CMM. I even installed the latest Firmware (6.10) to resolv that problem, but I did not change anything either. The blades are still working properly, but due to that massage I do not get any further option in Modular Server Control, e.g. remote KVM, shutting down etc. What else can I do to fix that issue?
Fini
Daniel_O_Intel
There are a few other things to try at http://www.intel.com/support/motherboards/server/sb/CS-030708.htm Intel� Modular Server Systems — Error: Component unfit - do you have two Ethernet Switch Modules installed, or just one?
TGeil
there are 2 modules installed. But what do they have to do with the compute units? One switch is not used at all at the moment.
Daniel_O_Intel
If you have two switch modules installed, the most common cause is admin link.
From the CMM GUI, choose System | Switches | Advanced Configuration
Mouse over any port and choose Port Configuration
Select Port | 10G.XC | Admin Status - if it is not already set for Down, set it for Down. Do the same thing for
Port | 10G.SC | Admin Status | Down
