5228 Discussions
Controller ID: 0 Phy is bad on enclosure: 1 PHY 24
SAljoshin
Hello!
We sold to customer 2 servers with same confguration and after 15 days of working both started to give such error on every restart.
Logs attached.
What could be a solution? Both 24slot backplanes broken?!
Sergei
SAljoshin
Hello Henry,
We discovered that it is not the latest FW for RAID controller used.
Seems like using latest FW solved the problem and HS is always online now.
We need to test a little bit, to be sure about that.
Sergei
Hello SergeiAljoshin,
I am really sorry for the problems you have encountered with Controller ID: 0 Phy is bad on enclosure, error message.
I will be more than glad to help you as much as possible.
Could you please provide me with a little more information on the server,
  • Server Motherboard model:
  • RAID Controller been use
  • or enclosure model
  • HDD been use
Also, if you need a faster response you can always contact or phone support team at 916 – 377 – 7000 option # 4.
Thank you for your time and patience.
If there is anything else we can help please feel free to ask.
Henry A.
SAljoshin
Hello Henry,
It is S2600CW2 motherboard,
RS3DC040 RAID controller,
In-WIN chassis 24 drives
Drives used: Hitachi UltraStar 7K6000 and Intel SSD DC S4500 and DC S4600
All firmwares and BIOS are the latest.
Servers worked 2 weeks 24/7 and did some Windows updates and did restart. After that both give such error.
regards,
Sergei
SAljoshin
Some additional information:
Chassis is:
IN WIN RS424-02M
And problem related to last drive which is a Hot Spare for RAID6.
I got one server to our test lab, so I can quickly provide additional information.
Right now no problems occur. But customer afraid that it will appear again.
Sergei
Thank you very much for the additional information.
I see that you are using a none Intel Chasis, but you are using S2600CW2 motherboard and an RS3DC040 RAID controller
Could you please provide me with the Storage drive cage backplane model number.
Also, the number of HDD you have configured.
Henry A.
SAljoshin
Hello Henry,
Sergei
I am glad the issue was resolved with flashing to latest FW.
I will pass on the information and with your permission I will close this threat.
Henry A.
