DBM10JNP2SB is not working
Dan_Piligrim
Good day. I bought motherboard DBM10JNP2SB  with parts: CPU Intel Xeon E-2244G  , memory DDR4 Samsung M393A4K40CB2-CTD 32Gb RDIMM ECC Reg PC4-21300 CL15 2666MHz .
I installed processor and memory, and use integrated video. I saw that coler on CPU is worked, but I saw no signal on monitor after turn on power .
What happens?
Wanner_G_Intel
Hello Dan_Piligrim,
Thank you for posting your question on this Intel Community.
We recommend that you check the following:
What is the number of DIMMs installed in the system?
Try booting the system with minimum configuration: CPU and 1 DIMM installed on A1.
4.2 General Memory Population Rules (Page 21)
https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/m10jnp2sb-user-guide.pdf
Have you tried using another VGA cable and/or display?
Since the processor has onboard graphics, have you tried using the DisplayPorts* available on the board?
Are you getting any beep sounds?
Are you using a chassis validated by Intel? Please refer to Table 14. Reference Chassis Compatibility List.
https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/m10jnp2sb-config-guide.pdf
Wanner G.
Dan_Piligrim
I'm sorry for long time.
I installed one DIMM in the board on A1.
Yes, and I tested with graphic card and with out this.
I tested motherboard without chassis.
Wanner_G_Intel
Hello Dan_Piligrim,
This is a follow-up post to know if you were able to review the information we shared with you.
If you need any further assistance, please let us know.
Wanner G.
Wanner_G_Intel
Hello Dan_Piligrim,
We have not heard back from you in several days. For this reason, we will close this thread.
Wanner G.
