Disti pack vs OEM pack
YB
Can you help to advise what is the difference between below 2 products.
Is there any spec difference between these 2?
Understand that OEM pack's support will be provided by OEM side instead of Intel, how about Disti pack?
Thank you.
AdrianM_Intel
Hello YB,
Thank you for posting on the Intel® communities.
In regards to the Disti Pack, we provide the support since it is a motherboard from Intel without third-party customizations, the main difference between those products is that the OEM version as BBS2600CW2SKR is customized by Kontron, the board is from Intel but they do their own customizations, for example, Different chassis, BIOS version, custom BIOS and others.
Disti version comes without customizations from third-party companies so we can help with troubleshooting, warranty, etc as it comes directly from Intel.
Adrian M.
AdrianM_Intel
Hello YB,
Adrian M.
YB
Thank you for the detailed explanation, it is very helpful.
