공지
Drive fault led??
ATsit2
초보자
3,416 조회수
Hello to all community...
I have a homemade server with this parts :
Cpu i3 560
M/b intel s3420gplc
Ram kingston kvr1333d3e9sk2/4gi 2x2gb
Raid controller srcsatawb raid 6
Disk 8x2tb wd2003fyys re4
Psu corsair hx850
Os win2008r2 standard
if a drive fault, how to know which drive fault of these drives?? the controller has 8x2 pins for drive fault led..
i searched for more technical detailes in intel site and nothing found..
can any one help??
thank you..
7 응답
Edward_Z_Intel
2,061 조회수
Only if you're using a hot-swap backplane that supports drive fault LED, and you have connected the correct cable to the backplane.
0 포인트
ATsit2
초보자
2,061 조회수
Dear Edward.. your answer is very helpful.. now i'm serching for backplane..
the backplanes of intel.... at this http://download.intel.com/support/motherboards/server/sb/backplane_cabling_for_s5000_pedestal_systems_3_0.pdf pdf says that
Expander Backplanes:
AXX6DRV3GEXP or AXX4DRV3GEXP
SAS in-band.
No Fault LED control cable needed.
Note: Intel® RAID Controllers SRCSATAWB offers expander backplane support.
and
Non-Expander Backplanes:
AXX6DRV3G or AXX4DRV3G
RAID card connector: J6, white
Backplane connector: SES, white
Cable: 3-pin SES
Note: RAID FW 420 or higher is required.
which of these is the best solution for me to choose??
please remember that my controller has 8x2 fault drive pins.
Edward_Z_Intel
2,061 조회수
Both will work with your controller. If you use a expander backplane, you don't need any cable besides the SAS data cable. If you use a non-expander backplane, you'll need to connect the 3-pin SES cable for the drive fault LED to work properly. I believe the cable comes with the backplane. The 8x2 fault drive pins are not used with Intel backplane.
0 포인트
ATsit2
초보자
2,061 조회수
f i connect a hdd activity led to one of these 8x2 pins and before i boot the server i disable one or two drive/s for drive failure, i think the led start blinking?? is that true??.. or if you have something to suggest it will be more helpful for me..
0 포인트
Edward_Z_Intel
2,061 조회수
That 8x2 pins connector gives you 8 fault LED signals - one LED per drive. Meaning if you connect the HDD activity LED to two pins for drive 1, and then your drive 2 fails, the LED won't start blinking. LED behavior is documented in http://www.intel.com/support/motherboards/server/srcsatawb/sb/CS-028266.htm TPS section 2.7.4.1. It won't be necessary if you're using an Intel backplane.
0 포인트
ATsit2
초보자
2,061 조회수
and if i connect 8 leds??
if any drive from 8 that are connected on the controller faild.. that led shuld be blinking
is that correct??
0 포인트
Edward_Z_Intel
2,061 조회수
0 포인트
응답
