5228 Discussions
Having difficulty locating the BMC LAN IP configuration option in the Aptio Setup Utility (Megatrends 2012).
TAlbe3
I don't see it under the Server Management tab in the BIOS. Does anyone know how to get to it?
Board part # is G62254-406
BMC firmware rev is 1.13.8619
We configured it but now cannot access via http:.
looking to change the IP so that we can get to it again.
To answer your question, the option is located under Advanced>BMC LAN Configuration. If you are not showing this option proceed to update the firmware to the latest version which can found here:
https://downloadcenter.intel.com/download/25830/Intel-Server-Board-S1200V3RPL-S1200V3RPO-S1200V3RPM-Firmware-Update-Package-for-EFI Download Intel® Server Board S1200V3RPL/S1200V3RPO/S1200V3RPM Firmware Update Package for EFI
