5228 Discussions
How I can change VLAN from CLI (ipmitool) ?
Sergey_C_Intel
I have Intel server. I can change VLAN from web interface but I can't to do it by CLI (ipmitool) ?
If I try to do it by ipmitool it's fail
  ./ipmitool -I open lan set 1 vlan id 216
  VLAN ID must be between 1 and 4094.
And one more question how to reset BMC to fabric default from CLI ?
In my BMC standard way is not worked
./ipmitool -I open raw 0x3c 0x40
Unable to send RAW command (channel=0x0 netfn=0x3c lun=0x0 cmd=0x40 rsp=0xc1): Invalid command
./ipmitool -I open raw 0x30 0x40
Unable to send RAW command (channel=0x0 netfn=0x30 lun=0x0 cmd=0x40 rsp=0xc7): Request data length invalid
What am I doing wrong ?
Thanks for your time
For more info see below
server S2600WFT
Product Part Number : H97428-011
Product Version : R1208WFTYS
BMC
./ipmitool -I open bmc info
Device ID   : 34
Device Revision  : 1
Firmware Revision  : 1.74
IPMI Version  : 2.0
Manufacturer ID  : 343
Manufacturer Name  : Unknown (0x157)
Product ID  : 123 (0x007b)
Product Name  : Unknown (0x7B)
Device Available  : yes
Provides Device SDRs : no
Additional Device Support :
 Sensor Device
 SDR Repository Device
 SEL Device
 FRU Inventory Device
 IPMB Event Receiver
 Chassis Device
Aux Firmware Rev Info :
 0x2a
 0x40
 0x39
 0xee
or
./ipmitool -I open raw 0x30 0x71 0x00 0x01 0x00 0x00
 11 00
ipmitool -V
ipmitool version 1.8.18m4_esyscmd_s(./csv-revision)
./ipmitool -I open lan print
Set in Progress  : Set Complete
Auth Type Support : MD5 PASSWORD
Auth Type Enable : Callback :
   : User :
   : Operator :
   : Admin :
   : OEM :
IP Address Source : Static Address
SNMP Community String : public
IP Header  : TTL=0x40 Flags=0x40 Precedence=0x00 TOS=0x10
BMC ARP Control  : ARP Responses Enabled, Gratuitous ARP Disabled
Gratituous ARP Intrvl : 2.0 seconds
Default Gateway MAC : 00:00:00:00:00:00
Backup Gateway IP : 0.0.0.0
Backup Gateway MAC : 00:00:00:00:00:00
802.1q VLAN ID  : 216
802.1q VLAN Priority : 0
RMCP+ Cipher Suites : 1,2,3,6,7,8,11,12,15,16,17
Cipher Suite Priv Max : XXaXXXXXXXaXXXX
   : X=Cipher Suite Unused
   : c=CALLBACK
   : u=USER
   : o=OPERATOR
   : a=ADMIN
   : O=OEM
Bad Password Threshold : 3
Invalid password disable: yes
Attempt Count Reset Int.: 30
User Lockout Interval : 10
SergioS_Intel
Hello SCher16,
Please allow us to investigate on your question and we will get back to you as soon as possible.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
SergioS_Intel
Hello SCher16,
First, we would like to apologize for the delay in our response.
IPMI tool is an industry-wide tool and is not proprietary to Intel, you can check the IPMI tool's command and their usage at https://www.systutorials.com/docs/linux/man/1-ipmitool/, you can set VLAN id and reset BMC.
Sergio S.
A Contingent Worker at Intel
Sergey_C_Intel
​Hi Sergio
Maybe I'm doing something wrong, but if you read my post (above), you can see that I have already tried setting the VLAN id
and it doesn’t work on my motherboard via ipmitool (that’s why I indicated the name of the motherboard and bmsi authentication).
That is why I had a question whether it is possible to register VLAN id using raw commands or some other linux utilities
SergioS_Intel
Hello SCher16,
Sergio S.
SergioS_Intel
Hello SCher16,,
We have checked on the parameter with vlan if it is supported within the IPMI tool - https://www.systutorials.com/docs/linux/man/1-ipmitool/, can you please let us know if you still have the same problem?
Sergio S.
SergioS_Intel
Hello SCher16,
We are following your question and we would like to know if you need more assistance.
Sergio S.
SergioS_Intel
Hello SCher16,
Sergio S.
SergioS_Intel
Hello SCher16,
Sergio S.
