5203 Discussions
I want to get power consumption of Intel server.
DamRin
Currently, S2600WFT has purchased and used this product
My specifications are as follows
os : centOS8
IPMITOOL : 1.8.18
bios : 02.01.0017
bmc fw : 2.88. e172ff67
when entering the ipmitool dcmi power reading command, there is an error as below and it is not output.
"DCMI request failed because: Invalid command (c1)"
Please let me know how to use ipmitool dcmi power reading.
vij1
Hello DamRin,
Greetings for the day!
Thank you for reaching out to the Intel community. Kindly share the screenshot of the error you are facing.
Vijay N
DamRin
첨부파일로 첨부 하였습니다.
vij1
Hello DamRin,
Please note the Cipher Suite 17 was first introduced in ipmitool 1.8.18 on Oct 8th 2016, you have to update ipmitool to this version or newer one, earlier versions of ipmitool don’t have Cipher 17 support.
ipmitool is not working well when running in high load network. We recommend to add extra timeout by using “-N 5”. Default is 1 second for RMCP+, which is not enough. –N 5 will set 5 second as timeout.
So the command will look like:
ipmitool –I lanplus –H ip –U user –P password –C 17 –N 5 command
Please refer to the included "TA-1143_Extra_parameters_needed_for_ipmitool.pdf" for more information.
https://downloadmirror.intel.com/728430/TA-1143_Extra_parameters_needed_for_ipmitool.pdf
Vijay N.
DamRin
나는 os에서 바로 실행하기 때문에 lanplus 라는 명령어를 사용할 필요가 없다
os에 ipmitool 설치하고 아래와 같이 입력하면 동일한 에러가 난다
~]# ipmitool -N 5 dcmi power reading
내가 봤을땐 인텔서버에서 해당 command 를 지원하지 않는거 같다.
vij1
Hello Daniel,
Could you please confirm if you have tried any other IPMI commands on this server? If yes, please share the results and the commands that you used. This information will help us assist you further.
Vijay N.
vij1
Hello Daniel,
We are currently awaiting your response regarding the case. If you have any queries or require further assistance, please feel free to respond on the community post. We are more than happy to assist you.
Vijay N.
vij1
Hello Daniel,
We have been awaiting your response regarding the query and unfortunately, we have not received any communication from you.
We regrettably need to close the request, if you still require assistance or have additional questions, Please don't hesitate to ask any further questions in the future. Feel free to start a new conversation, as this thread will no longer be monitored.
We appreciate your understanding and value your business. Should you need assistance in the future, please don't hesitate to reach out.
Vijay N.
