5223 Discussions
IMS Switch 10G.XC interlink causes loop
Hi there,
i got a MFSYS25V2 with 2 Switches.
Since upgrade to firmware version 11.5 i have the following problem.
On both switches i configured a VLAN with e.g. VLAN-ID 55 on only one single external port as untagged, not on the 10G.XC interlink port.
I also have two Dell PowerConnect switches.
When i connect these components as show in the graphic below, i get a loop.
Note:
- The 10G.XC interlink is not member of the VLAN-ID 55.
- all Servers are shut down
- jumbo frames on all switches are enabled (also tried with disabled)
Is there a known bug in the new firmware version 11.5?
Daniel_O_Intel
For all versions of firmware, not just 11.5, it is recommended to keep that link disabled.
Thank you for answering.
I'm using this 10G.XC link for several VLANs.
Only a single one should be used like described in my question.
So my question is answer but the problem still exists.
Daniel_O_Intel
You can disable that link, regardless of VLAN assignment.
