- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
We have a Server with Integrated RAID Module RMS3CC040 (Firmware Package V: 24.21.0-0012, Firmware Version: 4.680.00-8249) with 3 Samsung 850 Pro Drives RAID 0 (HS)
Every Reboot the Controller shows 3 Warnings: Controller ID: 0 PD is not enterprise class self encrypting drive. Encryption capability of the drive will be disabled -:-:0
We Use AVAGo MSM 17.05.00.02
Any suggestions or ideas ? Thanks in advance.
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Silvan,
This usually happens when the drive in use does not meet the requirements for the Drive Encryption settings. If you are using any type of encryption, please disable it and reboot the server to test. In addition to this, you can also disable the Drive Security from the RAID BIOS if it is not being used.
Keep in mind that some RAID solutions require additional hardware to enable features like the Drive Encryption.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Silvan,
Is there any update on this thread? Is there anything else that I can do for you?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi GerorgeSV
Thanks for your reply.
I tried to disable the encryption on the controller, In the Bios or with the MSM. But i could not found the setting.
may you can guide me where i can find this setting?
Thanks in advance.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Silvan,
Thank you for contacting Intel(R) Technical Support.
You can try by physically moving a jumper on the RAID controller, which is the Premium Feature Key Header. Is a -3- pin header located on the RAID controller. It is label as JT5.
Attached is a layout of the RAID Controller, you can use this to locate the jumper on the card.
Please let me know your results.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi
Thanks for the reply.
I checked the jumpers and see that the JT5 is not set. So you think i have to set this jumper to disable disk encryption?
Thank in advance
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi
I also attached the diagnosticlog from Intel RAID-Webconsole3. May this gives you some more informations to help me.
best regards
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Silvan,
Thank you for your response.
I looked at the picture and the JT5 jumper shows only 2-pin. This should be a 3-pin header. I attached a screenshot with some instructions on how to disable the drive security. Please try these instructions and let me know if they work.
Jeremiah A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Jeremiah
Thanks for your reply. I tried it as you described. But the "Drive Security" cant be selected. It's greyed out.
best regards,
Silvan
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Silvan,
Thank you for your update.
Let me go ahead and investigate this issue and get back to you as soon as possible with new information; as noticed in the picture you sent that there is a missing ping on JT5 3-pin header.
Jeremiah A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Silvan,
I hope you are doing well today.
I'm still investigating regarding this issue. Based on the error: " PD is not enterprise class self encrypting drive. Encryption capability of the drive will be disabled" I want to check if you already tried a different type of drive? Also, can you please indicate the server model on which you are running this RAID controller?
Jeremiah A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Jeremiah
Thanks for your support.
Mainboard: Intel S1200SP
Bios: S1200SP.86B.03.01.0026.092720170729
I have used differnt drives. With the Samsung Pro 850/860 i have this Message.
With a Seagate ST4000NM00351V4 we have no warnings.
The warnings occoure even if the Disks are unconfigured.
Thanks in advance and greetings
Silvan
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Silvan,
I will look into this information and get back to you as soon as possible.
Jeremiah A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Silvan,
Jeremiah A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Silvan,
I apologize for the delay on this case.
The error message appears to be normal based on the disks used.
The Seagate drives are Enterprise drives as per Seagate's website:
https://www.seagate.com/www-content/product-content/enterprise-hdd-fam/enterprise-capacity-3-5-hdd/enterprise-capacity-3-5-hdd/en-us/docs/100793636c.pdf https://www.seagate.com/www-content/product-content/enterprise-hdd-fam/enterprise-capacity-3-5-hdd/enterprise-capacity-3-5-hdd/en-us/docs/100793636c.pdf
While the Samsung Pro drives are not:
http://www.samsung.com/semiconductor/minisite/ssd/product/consumer/850pro/ http://www.samsung.com/semiconductor/minisite/ssd/product/consumer/850pro/
So, as you can see the errors that are coming up are normal. You need to use enterprise hard drives to avoid the error message.
Jeremiah A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Silvan,
I following up with you to see if there is anything else we can help you with or if can proceed in closing this case.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Silvan,
I have not heard from in regards to this case. I will proceed in closing the case. If you need more assistance from us feel free to contact us again.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
