5316 Discussions
Intel Active System Console and Windows Server 2008 R2 Hyper-V Core
BSupp1
Dear Intel Community,
We've taken on a new client that has existing Intel Hardware, which has Windows Server 2008 R2 Hyper-V Core Edition installed. I would like to get Intel Active System Console running in this environment however I'm not familiar with Hyper-V Core and it's abilities. I understand that Hyper-V Core is Windows Server without the GUI but I've not yet got the software to work.
I've managed to install the software through command prompt however when you attempt to run the software it will not load, Has anyone been successful with installing this product in this environment?
David_A_Intel
What is the model of the system board you are using?
BSupp1
The model number of the system board that the server has is S5520HC.
David_A_Intel
I can check and see how we can access the Intel® Active System Console in your Hyper-V environment.
I was wondering if you might consider setting up the Integrated BMC Console instead. This will allow you to monitor the health of your system from the host machine, from a virtual machine, and from a client system on your network. You may event set this up to have remote access from the outside.
BSupp1
Hi David,
Thanks for the response, we already have the BMC set-up and we can access this remotely if needed however I find that the user interface isn't user friendly and the lay out isn't great either, which is why I was hoping someone may have got the Intel Active System Console tool running in this environment.
thanks again for the response and idea though.
