5201 Discussions
Intel Driver & Support Assistant resulting in an endless scan...2
Yesid
Alberto_Sykes
Yesid, Thank you for posting in the Intel® Communities Support.
For this specific scenario, we recommend to try scanning with different browsers since Intel® DSA only works with the following: Chrome, Firefox and Edge. Then you can also try to clear the browser cache and then try rescanning the Intel® DSA tool.
If the problem persists, run the Intel® Driver & Support Assistant Uninstaller version 20.11.50.9:
https://downloadcenter.intel.com/download/30068/Intel-Driver-Support-Assistant-Uninstaller?v=t
Restart and install the latest Intel® Driver & Support Assistant tool version 20.10.42.5:
https://downloadcenter.intel.com/download/28425/Intel-Driver-Support-Assistant?product=128824
-If the issue remains, please provide the latest file from Intel® System Support Utility for Windows*:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91...
-The latest Intel® Driver & Support Assistant Uninstaller log file: using File Explorer, search for DSAUninstaller.log
-The latest Intel® Driver & Support Assistant log files: using File Explorer: go to folder = C:\ProgramData\Intel\DSA, and zip the Log files or entire folder.
Note: Uncheck "Hide System Files" to see the AppData folder.
Show hidden files
https://support.microsoft.com/en-us/help/14201/windows-show-hidden-files
Additionally, just to let you know, Intel® is aware of the situation, please keep checking the following thread for possible updates on this matter:
https://community.intel.com/t5/Intel-NUCs/Intel-Driver-amp-Support-Assistant-resulting-in-an-endless-scan/m-p/1235667#M78819
Also, was the Intel® DSA working fine on this platform previously? I just wanted to confirm that information because according to our web site, the tool is not supported by Windows* Server 2019:
Albert R.
A Contingent Worker at Intel
Alberto_Sykes
Hello Yesid, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_Sykes
Hello Yesid, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
Yesid
Excuse me for my late answer.
I've tryied firefox and chrome beforehand, with no success.
I also tried to uninstall and reinstall, without success.
Reading about the problem at https://community.intel.com/t5/Intel-NUCs/Intel-Driver-amp-Support-Assistant-resulting-in-an-endless-scan/m-p/1235667#M78819 was that I discovered a known problem,
and because the thread was closed, and was recommended to open a new thread to report that the problem persisted.
The last point it is that the OS is a Windows server 2019, instead of the previous Windows 10 on the same machine.
It was tested before, and it was funciontal, but with a different OS.
The question will be if there is any other approach we can use for it to work.
