5180 Discussions
Intel Modular Server RAID1 to RAID10
HI!
possible to modify subsequently RAID1 array to RAID10 in the modular server?
varga
Daniel_O_Intel
The Intel® Modular Server System MFSYS25/MFSYS35 does not support Virtual Drive Migration.
http://www.intel.com/support/motherboards/server/sb/CS-031195.htm http://www.intel.com/support/motherboards/server/sb/CS-031195.htm
HI!
Thank you for your reply. I am sorry, i'm wrote wrong system type. The system is MFSYS25V2. :-)
What about this?
Daniel_O_Intel
They have mostly the same features, so in this case the V2 doesn't have much significance.
From the User Guide at http://www.intel.com/support/motherboards/server/mfsys25v2/sb/CS-032891.htm http://www.intel.com/support/motherboards/server/mfsys25v2/sb/CS-032891.htm, the closest thing I see is:
Expand Expands the size of an existing virtual drive using any unallocated
space within the storage pool in which the virtual drive resides. Note:
This function is only available when the Intel® Modular Server
Storage Management Pack feature is activated.
Dear Dan_O!
Thank you very much!
V.
