5175 Discussions
Intel® RAID Controller SRCSATAWB time sync
My server Intel® RAID Controller SRCSATAWB, is losing time when ever it is down for more than 4 hours. I want to find out if there is a problem or is there a place where I can set in bios for the time to sync with the int. time server. I am running wind 2008 rs on hyper-v and my time server is a virtaul machine. Is it possible to point bios to internation time server.
Edward_Z_Intel
I don't think the time is with the RAID controller. It looks like that your BIOS battery on the main board is running out. If you want to use NTP, you should configure the OS to sync time using NTP.
