5184 Discussions
Intel S2600WFT ipmi tools, how to retrieve ip address from os centos 7
IShar3
Hello all. I have intel S2600WFT, I can't get info about ipmi lan address inside os Centos 7. For Supermicro I just use ipmitool and type # ipmitool lan print | grep 'IP Address'.
Is there any command or utils like this to get ipmi address?
Thanks a lot.
P.S. I google it, but can't find any relevant answer.
Ilnaz
Emeth_O_Intel
Hi Ilnaz, Thank you so much for contacting us about this concern. I would like to ask you some probing questions in order to gather more information and identify the root cause of the issue. Have you configure the IPMI on this system before? or is this the first time? Also, did you already configure the BMC on the system? Because in our systems the BMC needs to be set up in order to have the IPMI running. When you enter the command what is the output that the terminal shows? Have you tried to enter the command without the "| grep "IP Address" " ? Please let me know the outcome in order to proceed with the next step. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
Emeth_O_Intel
Hi Ilnaz, I am following up this thread in order to verify if you still need help on this, or if you have any other question in order to assist you with. if so, please let me know and I will be more than happy to assist you. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
Emeth_O_Intel
Hi Ilnaz,
I was checking this case and I noticed there is no activity from you since five day ago after the last follow up message. I am going to proceed and close this thread. If you have any other question please do not hesitate and contact us back and we will be more than happy to assist you.
Emeth O.
