- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Supports the Intel s3200shv motherboard EFI/UEFI boot ???
Can i install Windows Server on GPT disk?
Lien copié
7 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Kuznetsov,
Thank you for contacting Intel Technical Support.
I understand that you want to confirm if the Intel(R) Server Board S3200SHV support UEFI/ EFI and GPT disks. I can confirm that the server does support EFI, this can be verified in the Technical Product Specification located https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s3200sh/sb/e14960009_s3210sh_tps_r1_8.pdf here.
I'm still trying to confirm if the server supports GPT type disks; I will update the post as soon as possible with the information.
Intel(R) Technical Support
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Kuznetsov,
Can you please indicate which Windows Server and Hard Drive are planing to use with this server?
regards,
Jeremiah A.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Windows Server 2008 R2 (standart) x64
WD WD2003FYYS 7200rpm RE4 2.0Tb
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Kuznetsov,
Thank you for your quick response.
Based on Microsoft Support site, there is an issue when trying to install Windows Server 2008 R2 (standart) x64 in a disk that has GPT. But, there is resolution to prevent this issue. Please use the information from the following link:
https://support.microsoft.com/en-us/help/975535/you-cannot-install-windows-server-2008-r2-on-a-computer-that-uses-efi
Please let me know if there is something else we can help you with.
regards,
Jeremiah A.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Kuznetsov,
I hope you are doing well today.
I'm following up with you to see if the information helps or if you still need more assistance with the case.
Jeremiah A.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Kuznetsov,
Jeremiah A.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Kuznetsov,
Jeremiah A.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
