5173 토론
Intel S5000XVNSATAR Status LED blinking in amber
직원
4,199 조회수
i have an intel server board S5000XVNSATAR which has a system status LED blinking in amber color continuosly. I am unable to find the cause and correct the problem... this is my new board just 10 day old replaced it with my old server board S5000XVNSATA. My old motherboard had this issue 3yrs after its purchase , i ignored it and did not keep any follow up on the issue ... now just a month ago this motherboard had the system status LED in solid amber color... showed no sign of booting , no display , nothing happening. So i replaced it with a new one S5000xvnSATAR. Now my new motherboard is indicating this issue too early and i am afraid of loosing its functionality. Kindly help me understand what exactly is happening.
My Server Configuration :
Intel S5000XVNSATAR server board
16 gb Ram
Ati Radeon 5700 HD graphics Card.
Intel Xeon Quadcore E5310 x 2 , processors.
700Watt Seventec Power Supply.
0 포인트
9 응답
Edward_Z_Intel
2,729 조회수
Install and run the http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18895 sysinfo utility. Check the result files for errors.
0 포인트
직원
2,729 조회수
i tried running sysinfo.exe .. but the backend.exe fails to execute and crashes. I am using windows 7 ultimate... is this the issue ?
0 포인트
Edward_Z_Intel
2,729 조회수
Please go to windows\Binaries folder and run install.bat first. You may need to run it as administrator.
0 포인트
직원
2,729 조회수
i ran install.bat as an administrator and then i ran sysinfo.exe (as an administrator) and again the backend.exe crashed.
0 포인트
Edward_Z_Intel
2,729 조회수
Go to Device Manager and see if there is a device called "Microsoft Generic IPMI driver". Delete it and run install.bat again. That should install the Intel IPMI driver properly.
If sysinfo still doesn't run, try to run http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18871 SEL viewer to grab hardware events only.
0 포인트
직원
2,729 조회수
this didnot work at all , i get the same error. However i am providing the screen captured version of IMPI info using everest ultimate.Hope it may reflect the issues..
Here is the report generated
--------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
Version EVEREST v5.00.1650
Benchmark Module 2.4.258.0
Homepage http://www.lavalys.com/ http://www.lavalys.com/
Report Type Report Wizard
Computer QUADCORE-5310 (Quadcore-5310)
Generator gurbaksh
Operating System Microsoft Windows 7 Ultimate 6.1.7600
Date 2011-11-11
Time 20:14
--------[ IPMI ]--------------------------------------------------------------------------------------------------------
[ IPMI System Event Log ]
0004 11/10/2011 2:01:48 PM BMC SEL Disabled Log Cleared 42 0F FF
0018 11/10/2011 2:01:52 PM BMC Fan LoN Thresh OK now
002C 11/10/2011 2:01:52 PM BMC Fan LoC Thresh OK now
0040 11/10/2011 2:01:52 PM BMC Fan - 44 0F FF
0054 11/10/2011 2:01:52 PM BMC Fan - 45 0F FF
0068 11/10/2011 2:01:52 PM BMC Fan LoN Thresh OK now
007C 11/10/2011 2:01:52 PM BMC Fan LoC Thresh OK now
0090 11/10/2011 2:01:53 PM BMC Fan - 40 0F FF
00A4 11/10/2011 2:01:53 PM BMC Fan - 41 0F FF
00B8 11/10/2011 2:01:53 PM BMC Fan - 44 0F FF
00CC 11/10/2011 2:01:53 PM BMC Fan Lo Noncrit Thresh
00E0 11/10/2011 2:01:53 PM BMC Fan Lo Crit Thresh
00F4 11/10/2011 2:01:53 PM BMC Fan Lo Noncrit Thresh
0108 11/10/2011 2:01:53 PM BMC Fan Lo Crit Thresh
011C 11/10/2011 2:01:54 PM BMC Fan - 40 0F FF
0130 11/10/2011 2:01:54 PM BMC Fan - 41 0F FF
0144 11/10/2011 2:01:54 PM BMC Fan - 45 0F FF
0158 11/10/2011 2:02:23 PM BIOS System Event Boot: ClockSync 1 05 00 FF
016C 11/10/2011 2:02:23 PM BIOS System Event Boot: ClockSync 2 05 80 FF
0180 11/10/2011 2:03:17 PM MemCtlr System Event - 01 FF 00
0194 11/10/2011 2:03:34 PM BMC ACPI Power State S0/G0 Working 40 0F FF
01A8 11/10/2011 9:45:44 PM BMC Fan Lo Noncrit Thresh
01BC 11/10/2011 9:45:45 PM BMC Fan Lo Crit Thresh
01D0 11/10/2011 11:09:37 PM BMC Fan Lo Noncrit Thresh
01E4 11/10/2011 11:09:37 PM BMC Fan Lo Crit Thresh
01F8 11/11/2011 2:47:02 AM BIOS System Event Boot: ClockSync 1 05 00 FF
020C 11/11/2011 2:47:02 AM BIOS System Event Boot: ClockSync 2 05 80 FF
0220 11/11/2011 2:47:02 AM BMC Power Unit Power Off 40 0F FF
0234 11/11/2011 2:47:03 AM BMC ACPI Power State S5/G2 soft-off 45 0F FF
0248 11/11/2011 2:47:03 AM BMC Platform Security - 40 0F FF
025C 11/11/2011 1:34:53 PM BMC Processor Present 47 0F FF
0270 11/11/2011 1:34:53 PM BMC Processor Present 47 0F FF
0284 11/11/2011 2:47:31 AM BMC Power Unit AC Lost 44 0F FF
0298 11/11/2011 1:34:55 PM BMC Power Unit AC Regained 44 0F FF
02AC 11/11/2011 1:34:56 PM BMC Power Supply - 46 0F FF
02C0 11/11/2011 1:34:56 PM BMC Power Supply - 46 0F FF
02D4 11/11/2011 1:35:11 PM BMC Button Power Button Pressed 40 0F FF
02E8 11/11/2011 1:35:14 PM BMC Fan - 40 0F FF
02FC 11/11/2011 1:35:14 PM BMC Fan Lo Noncrit Thresh
0310 11/11/2011 1:35:14 PM BMC Fan Lo Crit Thresh
0324 11/11/2011 1:35:14 PM BMC Fan - 40 0F FF
0338 11/11/2011 1:35:14 PM BMC Fan - 41 0F FF
034C 11/11/2011 1:35:14 PM BMC Fan - 43 0F FF
0360 11/11/2011 1:35:15 PM BMC Fan Lo Noncrit Thresh
0374 ...
0 포인트
Edward_Z_Intel
2,729 조회수
OK I noticed SYS FAN 4 is not getting any readings. If you don't have a fan connected to SYS FAN 4, run FRUSDR update again and select the corret fans.
0 포인트
직원
2,729 조회수
Yes ! Finally the "System Status LED is static green". I ran the FRUSDR,BIOS & BMC update with Intel Deployement Assistant and got the FAN issue resolved.
My question to you ..Can i perform any diagonistics with my previous Board (S5000xvnSATA) , it has "System Status Led" in Static Amber color , on powering the machine .. the CPU fans run but i can't see any Display... except this LED no other LEDs are glowing.
0 포인트
Edward_Z_Intel
2,729 조회수
If the same components works on another board then most likely it's board failure. You may try to clear COMS and select BIOS bank using the jumper. For more information, refer to the http://www.intel.com/support/motherboards/server/s5000xvn/sb/CS-023168.htm Technical product specification.
0 포인트
응답
