Intel S520HC beeps
I have a Intel S520HC serverboard with 2 Xeon Processor e5620 and 8GB RAM Kingston KVR1333D3D8R9S/2GI (x 4).
The ram is 1333mhz but my system see it 1067mhz...Why? I need to update anything?
When i start the server i have 3 beet shorts, in the manual this is for a RAM ERROR, but i dont understand because all my 8GB was read by the system....
Another question is: you know if is possible to install Snow Leopard Apple on my server?
Thanx at all
GG
Edward_Z_Intel
Xeon E5620 supports 800 and 1066MHz memory speed, so 1333Mhz DIMM will work at 1066MHz. 3 short beeps does not indicate memory error. It's normal during POST. If you have memory error you'll get 3 long beeps and no display. You can hear that by powering up the system with no DIMM populated.
