5313 Discussions
Intel® Server System R2312WTTYS and network adapters
ANieś
we are thinking about buying R2312WTTYS to forward network traffic. What we need is:
  • two 10GbE RJ45 interfeces - on the board (mainboard have two)
  • two 10GbE SFP+ interfaces with capability of connecting in range 10KM ( SMF LR )
  • two 40GbE interfaces, cabling doesn't matter
After searching the web we have found solutions:
  • Intel® Ethernet Converged Network Adapter X520-LR1 with Moduł SFP+ E10GSFPLR - unfortunately i don't know if it is compatible with R2312WTTYS
  • Intel I/O Module 10GbE AXX10GBNIAIOM - unfortunately here i can't find any information about compatibility of SFP modules, especially SMF LR (Long Range) modules
For the 40GbE interfaces there wasn't a problem, we found:
  • I/O module XL710-QDA2 AXX2P40FRTIOM
  • and network card XL710QDA2 40Gb/s 2xQSFP
Maybe someone have similar problem and can help?
SYeo3
Valued Contributor I
Hi Adam_N,
Thank you for contacting Intel. Your inquiry is best supported by our server engineers. They can guide you to the list of verified hardware.
Sincerely,
Sandy
SYeo3
Hi Adam_N,
Sincerely,
Sandy
ANieś
Hi Sandy,
can you tell me where i need to write to get the answer?
SYeo3
Hi Adam_N,
Not sure why our colleague marked my response as correct answer. I'm so sorry for the mistake.
Upon checking with our server engineers, the Intel X520-LR1 Network Adapter is compatible with Intel® Server System R2312WTTYS. Please refer to the website below for the list of compatible hardware for Intel® Server System R2000WT Family:
http://www.intel.com/support/motherboards/server/sb/CS-034852.htm Server Products — Memory and Hardware Compatibility
Thank you for your patience and understanding. Feel free to contact us back if you have further inquiries.
Sincerely,
Sandy
