5182 Discussions
Intel server board S2600CW2SR Powering
EAjis
I am building a server setup with 2 xeon e5 2690-v4 processor. on S2600CW2SR board , using BGear Powerminer 1200W PSU
The pc won't start, just getting error beep 1-5-4-4 and 1-5-4-2 despite the fact that the 24 Pin moptherboard and 8 Pin CPU are connected
Carlos_V_Intel1
Hello Emmanuel,
Thank you for contacting Intel.
My name is Charlie and I will be assisting you today.
This beep sequence indicates a power fault or failure. See https://www.intel.com/content/www/us/en/support/articles/000006001/server-products.html
How to fix it:
-Ensure that no loose standoff contacts the chassis, which would therefore cause grounding. This scenario is especially true with brand-new system integrations.
-Remove and reinsert the power supply or power supplies.
-See to it that both Central Processing Unit 1 (CPU1) and Central Processing Unit 2 (CPU2) power connectors are connected even if there isn't a second processor installed.
-If your system supports dual or redundant power supplies, start your computer using a single power supply.
-Test one processor at a time if your board has two.
-Update the motherboard system BIOS/firmware to the latest version.
This could be related to the PSU units, in case this won't fix the issue do you have Intel PSU to test?
We will be waiting for your outcomes.
Charlie V.
A Contingent Worker at Intel
EAjis
Thank you Charlie V.
I will work on the Computer following your advice when i am back home this weekend.
EAjis
Good morning Charlie,
I had tried all instruction but no luck , it kept giving same tone
Emmanuel
Max44
To solve this error you need some technical support. I would recommend you to get help from Intel support team. They can guide with an exact solution.
Max
EAjis
Thanks Max
Charlie from Intel support technical team had given me some possible way to solve the issue.
Carlos_V_Intel1
Hello Emmanuel,
Perfect, we will keep the forum open while we wait for your outcomes.
Have a good day.
SergioS_Intel
Hello EAjis,
In order to continue troubleshooting this issue, please test a different power supply unit, additionally, test your system with the minimal system configuration.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
SergioS_Intel
Hello EAjis,
I am following your case and we would like to know if you need further assistance.
Sergio S.
EAjis
Thanks Sergio for the followup, I had tested the PSU and its working perfectly, I had decided to get another motherboard and see what happen.
Emmanuel
SergioS_Intel
Hello EAjis,
You are more than welcome, please let us know if you want to keep this thread open or if we can close it.
Sergio S.
EAjis
Hello Sergio
the thread can be close, many thanks to all that respond to the thread
Warm regards
Emmanuel
SergioS_Intel
Hello EAjis,
We are going to close this thread as per your request. Please contact us back in case you need more assistance.
Sergio S.
