5201 Discussions
Is it Intel server Board S2600WT supported Mix vendor DIMM/Memory ?
SBarv1
DIMMs brand are Samsung and Micron. Four of the 24 slots are DIMM Micron and the rest are all Samsung.
So I want to know this configuration is supported or not ?
Emeth_O_Intel
Hello SBarv1,
Thank you for replying back.
You can implement a Multi-Vendor DIMMs on an Intel® Server Board S2600WF Family.
As long as, the specifications of the memories are the same due to the fact that if the specifications will not match properly it will cause an impact on the performance of the system, for instance, the latency. As far as possible, we recommend using the same vendor and the same model.
If you would like to see more information, please check the following article:
Please let me know if you have more questions and I will be more than happy to assist you.
Emeth O.
Intel Server Specialist.
Emeth_O_Intel
Hello SBarv1,
Thank you for contacting Intel Servers Community Support.
Answering your question, according to the Intel(R) Server Board S2600WT Technical Product Specification on section 4.5.2 (NVDIMMs population Rules).
It mentions that the NVDIMMs from different vendors may be mixed in the same system and even the same channel.
For more information, please check the link above it has more information about the System Memory.
If you have more questions, please do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
SBarv1
Thank you Emeth for quick reply.
Sorry this my mistake the Product Name is S2600WF and We are using below DIMM configuration, could you check below and let me know this mix vendor/ part number dimm configuration is supported on this system ?
Board Information Area (Version 1,Length 72)
Unicode Country Base : 00h
Manufacturing Time(mins) : Sat Aug 11 08:55:00 2018
Manufacturing Name(ASCII) : Intel Corporation
Product Name(ASCII) : S2600WF0
Part Number(ASCII) : H87179-853
Mftr FRU File ID(ASCII) : FRU Ver 1.43
DIMM
Number of system DIMM:24
 Slot Number    Size    Type    Speed    Manufacturer    Asset Tag    Serial Number    Part Number
CPU1_DIMM_A1 32768MB DDR4 2666MH Samsung 24584744 SH5724G4UNC26P2-SC
CPU1_DIMM_A2 32768MB DDR4 2666MH Samsung 23EE581E SH5724G4UNC26P2-SB
CPU1_DIMM_B1 32768MB DDR4 2666MH Micron 173A4918 36ASF4G72PZ-2G6D1
CPU1_DIMM_B2 32768MB DDR4 2666MH Micron 173A4913 36ASF4G72PZ-2G6D1
CPU1_DIMM_C1 32768MB DDR4 2666MH Samsung 23F848EF SH5724G4UNC26P2-SC
CPU1_DIMM_C2 32768MB DDR4 2666MH Samsung 23EE703E SH5724G4UNC26P2-SB
CPU1_DIMM_D1 32768MB DDR4 2666MH Samsung 23F84C7D SH5724G4UNC26P2-SC
CPU1_DIMM_D2 32768MB DDR4 2666MH Samsung 23F849E9 SH5724G4UNC26P2-SC
CPU1_DIMM_E1 32768MB DDR4 2666MH Samsung 23F84468 SH5724G4UNC26P2-SC
CPU1_DIMM_E2 32768MB DDR4 2666MH Samsung 23F84624 SH5724G4UNC26P2-SC
CPU1_DIMM_F1 32768MB DDR4 2666MH Samsung 23F84C7B SH5724G4UNC26P2-SC
CPU1_DIMM_F2 32768MB DDR4 2666MH Samsung 25CFC7E3 SH5724G4UNC26P2-SC
CPU2_DIMM_A1 32768MB DDR4 2666MH Samsung 23F84B08 SH5724G4UNC26P2-SC
CPU2_DIMM_A2 32768MB DDR4 2666MH Samsung 23F8325B SH5724G4UNC26P2-SC
CPU2_DIMM_B1 32768MB DDR4 2666MH Samsung 23F84C7F SH5724G4UNC26P2-SC
CPU2_DIMM_B2 32768MB DDR4 2666MH Micron 17C7386B 36ASF4G72PZ-2G6D1
CPU2_DIMM_C1 32768MB DDR4 2666MH Samsung 23F84850 SH5724G4UNC26P2-SC
CPU2_DIMM_C2 32768MB DDR4 2666MH Micron 18D1576A 36ASF4G72PZ-2G6D1
CPU2_DIMM_D1 32768MB DDR4 2666MH Samsung 23EE8F51 SH5724G4UNC26P2-SB
CPU2_DIMM_D2 32768MB DDR4 2666MH Samsung 23F84992 SH5724G4UNC26P2-SC
CPU2_DIMM_E1 32768MB DDR4 2666MH Samsung 23F848D7 SH5724G4UNC26P2-SC
CPU2_DIMM_E2 32768MB DDR4 2666MH Samsung 23F84BB8 SH5724G4UNC26P2-SC
CPU2_DIMM_F1 32768MB DDR4 2666MH Samsung 23F84D42 SH5724G4UNC26P2-SC
CPU2_DIMM_F2 32768MB DDR4 2666MH Samsung 23F84860 SH5724G4UNC26P2-SC
SBarv1
Waiting for your update...
Emeth_O_Intel
Hello SBarv1,
Emeth O.
Emeth_O_Intel
Hello SBarv1,
I would like to know if you still have more questions in order to help you.
If so, please let me know and I will be more than happy to assist you.
Have a wonderful day.
Emeth O.
Emeth_O_Intel
Hello SBarv1,
I have been following up on your case in order to verify if you still have questions?
I would like to know if you would like to keep this thread open? or If we can proceed with the closing of the thread accordingly.
Please let us know the outcome in order to proceed with the next step.
Emeth O.
SBarv1
Thank you Emeth.! Please close this thread.
SergioS_Intel
Hello SBarv1,
You are welcome before we close this thread please let us know if the is anything else we can do for you.
Sergio S.
