5180 Discussions
Is there a windows based RAID configuration utility for the Intel C600 Series on SuperMicro X10DAx
AJINC
Hello All,
I have a SuperMicro X10DAx motherboard with Intel C600 chipset running Windows 2016. I am looking for a windows based RAID configuration utility for the C600 SATA RAID controller  chipset.
I tried all that are on the SuperMicro website but they all fail the install with error 0x00000643.
Do you have any suggestions for an app to monitor / manage the RAID in windows?
Thank you for any suggestions
AJINC
DeancR_Intel
Hi AJINC,
Thank you for posting in the Community.
I appreciate your efforts for providing details about the issue with your SuperMicro X10DAx motherboard and Intel C600 chipset. I understand the frustration caused by the installation failures with the RAID configuration utilities.
I will check this further internally and get back to you with a suitable solution or alternative suggestions for managing your RAID configuration in Windows.
Dean R.
Subhashish
Hello AJINC,
Greetings from Intel !!
We understand that you are looking for Windows apps or utility for creating RAID. If you want to create RAID at an OS level then there are many third party software available but Intel cannot comment on it or promote any 3rd party application. Hence we are unable to suggest. But for Windows itself (as you are using Windows 2016), Possible ways to create RAID is by using disk management. Since your windows is 2016, then it should have Storage Spaces, which is similar to RAID. Would like to confirm if you have explored those options?
Also you have mentioned you tried all that is available/suggested in SuperMicro Site, but gives error- 0x00000643, could you please elaborate on what all are the steps that you tried?
Subhashish_Intel.
Subhashish
Hello AJINC,
Greetings for the Day!!
This is just a follow up regarding the ongoing issue. We would like to know if you got the opportunity to review our last post. Please let us know if you need any help or have any questions.
Subhashish_Intel.
Subhashish
Hello AJINC,
Greetings !!
This is just a follow up regarding the ongoing issue. We're eager to ensure a swift resolution and would appreciate any update from your end.
Please write back to us for any issue or assistance required.
Subhashish_Intel.
AJINC
The application began to work and I can now create / monitor & modify my RAID volumes.
Thank you for your assitance.
Amina_Sadiya
Hello Team,
Greetings of the day!
Thank you for confirmation. Please let us know if you have any further questions or concerns. If No, Could you please confirm if we can go ahead and close this case.
kindly reach out to us we are happy to help you.
Amina
AJINC
Yes you can close this case
Thank You
