5219 Discussions
Manage and Monitor multiple Intel Servers in a Console
SDiem
Hi
Is there a Management Console for multilple intel servers. (Like HP SIM)
Thanks in advance
Hello Siliconbrain,
Thank you for joining the community.
Intel has a tool similar to what you describe. It is called the https://downloadcenter.intel.com/download/27472/Intel-Multi-Server-Manager-for-Intel-Server-Boards-and-Intel-Server-Systems Intel® Multi-Server Manager for Intel® Server Boards and Intel® Server Systems. The user guide can be downloaded from here: https://www.intel.com/content/dam/support/us/en/documents/server-products/IMSM_UserGuide.pdf https://www.intel.com/content/dam/support/us/en/documents/server-products/IMSM_UserGuide.pdf.
Keep in mind that this tool is for the following Linux distributions only:
1. Red Hat Enterprise Linux* 6.8 and 7.3
2. SuSE Linux Enterprise Server* 11.4 and 12.2
3. CentOS 7.3
Hope this helps
Jose A.
Hello Siliconbrain,
Do you have any updates, questions or comments in regards to this issue?
Please do not hesitate to contact us back.
If you consider the issue to be completed please let us know so we can proceed to mark this thread as resolved.
Jose A.
Hello Siliconbrain,
This thread will be marked as resolved automatically in the next 48 hours if no activity is received.
Jose A.
SDiem
Hi Jose A.
So, there's is no way to add VMware Hosts.
Thakns in advance
Siliconbrain
Hello Siliconbrain,
When you say VMware hosts you mean the actual host OS running on the server, or a guest OS (virtual machine)? HP SIM supports Linux OS running as guest on a VMWare host only.
Either way the IMSM runs on hosts with the supported Linux distributions only (RHEL, SLES, CentOS). Any other configuration like try to install it on a guest VM has not been tested.
Jose A.
Hello Siliconbrain,
Jose A.
Hello Siliconbrain,
Jose A.
Hello Siliconbrain,
We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and create a new topic.
Jose A.
