5199 Discussions
Management software for single server based on S3200SH?
Sorry to duplicate this question I posted in another discussion area; I did not see this section before posting there.
Software included with board is ISM ver 2. Would like to install the simplest software set to monitor this server's hardware. Install CD points toward instaling Microsoft System Center Essentials, which appears to me to be overkill(?).
Is there a new version that would give me just the local agent and a console to see the monitored items? Thank you!
Actually, you can use the software Intel Active Console to see the monitored items.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17671 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17671
Let me know which OS you have, i can help you thru the installation, if needed.
I have attached a screenshot of the Intel Active Console.
All the best,
Aryan
Thank you for your answer. I was able to acconplish the software installation, but the install corrupted the webserver configuration. We are now in midst of recovering that. While the software was installed, it was able to show information about the hardware. Thank you again.
