Microprocessor
BaldEagle
Hi
My system is fitted with an Intel Xeon CPUE3-1225v3@3.20Ghz Microprocessor
Is there a faster Microprocessor that I ca install.
Thanks in advance
AlHill
This is your processor from 12 years ago:
https://www.intel.com/content/www/us/en/products/sku/75461/intel-xeon-processor-e31225-v3-8m-cache-3-20-ghz/specifications.html?wapkw=E3-1225v3
It uses socket LGA1150.
But, there is much more.  You need to ask your motherboard provider what processors THEIR bios supports.  Once you do that, view the resulting list for a faster processor.  An upgrade processor must be socket, chipset, AND BIOS compatible.
[W10 is this generation's XP]
Azhari_Intel
Hello BaldEagle,
Thank you for posting in Intel Community.
As per suggested by @AlHill earlier, referring to the motherboard provider would be best to ensure your upgraded processor is supported.
Please refer to the link below which should highlight your current processor in use is LGA1150 socket type.
https://www.intel.com/content/www/us/en/products/sku/75461/intel-xeon-processor-e31225-v3-8m-cache-3-20-ghz/specifications.html#:~:text=Sockets%20Supported-,FCLGA1150,-Max%20CPU%20Configuration
Azhari_Intel
Azhari_Intel
Hello BaldEagle,
This is a follow up message.
Thank you for trusting Intel with your business. As with all good things, your product has reached the end of its interactive technical support life. However, you can find Intel® Xeon® Processor E3-1225 v3 recommendations at Intel Community forums and additional information at the Discontinued Products website. It is our pleasure to continue to serve you with the next generation of Intel innovation at Intel.com.
We will proceed to close this case. If you find that you still required assistance, we kindly request you to respond to the case. This will allow us to either reopen the current case or initiate a new one.
It is our pleasure to continue to serve you with the next generation of Intel innovation at Intel.com. Thank you for using Intel products and services.
Azhari_Intel
