5185 Discussions
Omni-Path Fabric Design Related
SZaid
Referring the Intel® Server Board S2600BP and Intel® Compute Module HNS2600BP Product Family Integration and Service Guide .
1. # 558210 - https://cdrd.intel.com/v1/dl/getContent/558210?wapkw=omni-path+fabric Intel Omni-Path Fabric Carrier Card Fab3 - Design Kit - Revision 2.2
2. # 554502 - Riser Card .
From the Step File Of The Riser Card - Its Clear that the Riser Card will not mate With the S2600BP design.
Could you Locate us to the right Design of the Riser Card For Buchanan Pass.
SZaid
Additional Information -
For the Riser Card Suggested - for Omni-Path design is # 554502
Hi ZAID,
Thank you for reaching out.
If I'm understanding your question, this a compatibility inquiry about what riser card to use on Intel® Compute Module HNS2600BP in order to support fabric adapters, if that is the case, according to the spare list and configuration guide for this system the raiser to use is: MM# - 948931 and the adapters to go with it are https://ark.intel.com/products/92004/Intel-Omni-Path-Host-Fabric-Interface-Adapter-100-Series-1-Port-PCIe-x8 Intel® Omni-Path Host Fabric Interface Adapter 100 Series 1 Port PCIe x8 and https://ark.intel.com/products/92007/Intel-Omni-Path-Host-Fabric-Interface-Adapter-100-Series-1-Port-PCIe-x16 Intel® Omni-Path Host Fabric Interface Adapter 100 Series 1 Port PCIe x16
Please let me know if this answers to your question or if further assistance is required.
Ken
Intel Customer Support
SZaid
Ken,
From the Design Guide of [Intel® Omni-Path Internal Faceplate Transition (IFT) Carrier Card ] - Its Noted That the Riser Card # 554502 is Suggested.
Referring to your response, related to the design of Riser Card- Can we get access to Design guide or Reference Brd file ?
The Question Is Related from a design POV. Access to Reference of the Riser Card? [ IBL num Would be helpfull]
HI,
Thanks for the clarification, I'll check on that and be back with you as soon as I get an answer for you.
Ken.
Hello ZAID,
I'm sorry for the delay, I just con firmed the information could be provided under a non disclosure agreement.
I'm sending an email to your registered address to start the process please continue communication by that mean.
Ken
SZaid
Ken,
Thanks for the support extended.
I have Shared with you all the details As Requested.
I hope You are Clear on the Files That we need,
1. Ref File For OPA Fabric Board
2. Riser CARD for its Plugin on buchanan Pass S2600BP
  • > AHW1URISER1
  • > AHW1UM2RISER2
Thank you,
WE received the information and will proceed on to the next step, once again thank you so much, you'll be contacted as soon as an answer for your inquiry is found.
Ken
SZaid
Ken,
Any positive response- please Update.
SZaid
Ken ,
The Issue We have Raised is Still Open.
We Seek your Support to have it closed at the Earliest.
Kindly Update us.
