PMBus in S2600CP Server board
Hi~
Is PMBus in S2600CP server board connected to CPU's I2C bus or IPMI?
If PMBus is connected to IPMI, which IPMI commands we can use to monitor and control it?
Would you show any example?
Thanks, in advance
David_A_Intel
We have some examples listed on a previous /message/216039# 216039 post of possible commands you may run to test the power supplies. You may use the http://download.intel.com/support/motherboards/server/sb/intel_rmm4_bmc_ews_userguide_r2_8.pdf Integrated BMC Web Console to monitor the status of the power supplies and control their function.
