Hello parnulfos,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Server Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Norman S.
Hi parnulfos,
Thank you for posting in Intel Community Forum
Please refer below for details of Xeon 6976 required:
Package dimension: 104.5 x 70.5mm
FCLGA Socket : 7529 pins
Intel® Xeon® 6900-series Processors (codenamed Granite Rapids-AP) SKUs use the Socket LGA7529-1 and the enabled loading mechanism requires a Package Carrier. Below is the carrier type for the package for Xeon 6900 series:
E2A ( Intel® Xeon® 6900-series - Granite Rapids-AP)
You may want to refer link below if you require any information related to this Xeon 6979 (Xeon 6900 series):
Some of the documentation from Intel Resource and Documentation Center (RDC) required an active CNDA for the access. If you do not have any RDC access, please refer to the links below:
How to Apply for an Intel® Resource and Documentation Center (RDC) and/or Intel® Developer Zone (Intel® DevZone) Account:
If you have the access, you may refer to links provided below:
RDC link : https://www.intel.com/content/www/us/en/resources-documentation/developer.html#gs.5k1ay6
Hope this clarifies your enquiry.
Sazzy_Intel
Hi parnulfos,
Greetings.
I would like to follow up with you regarding this case. May I know if everything is working fine and if you still require our assistance? If yes, kindly let us know.
Sazzy_Intel
Hi parnulfos,
Good day
This is regarding your enquiries above. Since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
