Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
5174 Discussions
Problems with cores and CPUs (on servers)
Francisco_Guerrero
Hi
I'm having a problem. My provider wants to standardize the CPU frequency at the same speed (2.4 GHz). This task has already been done at the hardware level, but it's not fully reflected at the operating system level. For example, when running: "cat /proc/cpuinfo | grep MHz | sort | uniq -c", differences in CPU frequency are still visible. Now, there's the issue of cores/threads, and in the image, I assume they are threads and not cores (already standardized at the hardware level).
Intel(R) Xeon(R) Platinum 8260 CPU @ 2.40GHz
OS version is RedHat 8.10.
Model servers:  Lenovo SR850P, 950 and 650
OttoChow
From the numbers, I assume that your server has 4 processor and Hyperthreading is enabled.   Xeon 8260 is a 24 core processor.  With hyperthreading enabled (by default), it support 48 logical cores per processor.  /proc/cpuinfo shows  that there is 192 CPU .... that is 192 logical cores.    If your question is ... there is still 1 logical CPU is not running at 2.4GHz.  You need to ensure that the CPU power saving feature such as C-State (C6, C1) and Speed Step Technology are all disabled at BIOS level.
Then all CPU cores of the server will run at base frequency - 2.4GHz.
Sachinks
Hello Francisco_Guerrero,
Greetings!
We understand that you have a concern related to the standardization of the CPU frequency.
Kindly let us know if the details provided above ( ensuring that the CPU power saving feature such as C-State (C6, C1) and Speed Step Technology are all disabled at BIOS level) are helpful.
Also, we see that this processor is a tray processor. Hence, as these processors are shipped with the system ( Lenovo), we request you to check this further with Lenovo itself as they will be best equipped to assist you with this.
Sachin KS
Francisco_Guerrero
Hi
I'll follow the recommendation
Give me a chance to review it and I'll let you know shortly.
vish1
Greetings!!
Thank you for the update. Please keep us posted with any further developments.
Vishal Shet P
Francisco_Guerrero
Hi
I tested it on a Lenovo SR950P model with 8 sockets, turning off C-state and turbo mode. The result is better seen in image B.
Image A (before the change)
Image B:
I'll continue testing on different models in the coming days and update the progress.
Info server (CPU's):
Sazirah
Hi Francisco_Guerrero,
Thank you for sharing the update.
This is noted, kindly keep us posted on this.
Sazzy_Intel
Sachinks
Greetings for the day!
This is a follow up. Kindly let us know if you were able to contact Lenovo regarding this and kindly provide us an update.
Sachin KS
Sachinks
We would like to inform you that we are closing this request as no response has been received from our previous follow-ups.
Please don't hesitate to ask any further questions in the future. Feel free to start a new conversation, as this thread will no longer be monitored.
Sachin KS
