5182 Discussions
R2208WFTZSR S2600WFTR problems with disks
Andrei4
There is an R2208WFTZSR chassis with an S2600WFTR motherboard.
2 Intel PCI-E x4 1600Gb SSDPE2KE016T801 SSD disks are installed and connected to the motherboard with Oculink cables.
The disks are displayed in the BIOS.
Question: Is it possible to use these disks not in raid, but as two separate disks? What settings should I use to do this?
Also, 1 SSD Micron 7300 M.2 2280 is installed in the motherboard.
It is not displayed either in the BIOS or in the OS.
How to initialize it?
Andrei4
Hello Victor,
Thanks for the reply.
It's a pity to encounter this error in the configurator, but nothing can be done now - we will order another disk.
The problem can be considered solved. There will be no more questions about this situation.
Thanks again.
Victor_G_Intel
Hello Andrei4,
Thank you for your response.
We appreciate all the time and effort that you put into this matter, and we sincerely apologize for the misunderstanding. Since the thread can be considered solved, we will proceed to close it.
Victor G.
