5182 Discussions
Raid Web Console doesn't see raid
Hello
I work on windows server 2003 with controller Intel SRCSAS18E. I installed Raid Web Console 2 but I didn't see my raid. I try few times with different type of instalation (standalone, client, server). I have also second server with the same software and controller, there everthing work fine. I also installed raid web console on my host but result is the same. What should I have to do ?
Daniel_O_Intel
Did you install the one from here? http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2177&DwnldID=18440&lang=eng
I know Windows sometimes tries to block connections if you have the default Firewall services set up.
Yes, I tried this version.
I added port 5571 and 3071 to my firewall in w2k3, later I disabled firewall. I still can't connect to my raid.
Daniel_O_Intel
What error does it give?
I haven't any error. I don't see my raid on the list in the web console. I see only my second server *.*.*.200. I attached sreenshot. I take it on my server *.*.*.120 where I have problem with raid.
Daniel_O_Intel
Okay, if you see one server, but not the other, that's good - it means RAID Web Console is set up correctly. But it means something on the server .120 itself is blocking the inbound connection.
If you install RWC on server .200, does it only see server .120 and no one else?
In RWC:
on .200 server I see only raid .200
on .120 server I see only raid .200
on my host I see only raid .200
I have G-data Antivirus on .120. I disabled antivirus but still can't see the raid
Daniel_O_Intel
Good news is, you're on the right track. It's definitely a piece of software on .120 that is preventing the RWC from working.
Bad news is, you've already disabled firewall and antivirus, so I don't know what else to check.
LCern1
Took me a while to find a solution but for me on Windows 2012 R2 server enabling the following program on the Windows Firewall with Advanced Security was the fix for me:
C:\Program Files (x86)\RAID Web Console 2\Framework\VivaldiFramework.exe
