S1200BT vs SC5650DP
/community/openportit/server/ask Friends,
I have Intel motherboard S1200BT and chassis SC5650DP ...the problem is that the motherboard turn the case fans at maximum cooling. The room where the server cannot be located from the noise of the fans. Can someone tells you how I can control the fans.
P.S. Fan settings in the server configuration (number, position, etc.) to nothing.
Edward_Z_Intel
Unfortunately tried all possible options, updated the BIOS / firmware, tried different configurations of cases but nothing works, control acoustics in the BIOS is not available.
I conclude that the board is broken.
Edward_Z_Intel
Which chassis did you select when applying FRU/SDR? By default all fans will run at full speed when "Other" chassis is selected.
