- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I just finished to build a system with a S1200BTLR board and 4x8gb of ECC UDIMM validated by Intel for the board. Windows 7 is installed (workstation build).
Now, the problem is the following:
4 usb 2.0 port from the front panel are attached to an internal usb header. If I attach 1 or 2 devices to this 4-port panel, all works fine. If I attach a third of fourth device, *all* devices become non-operational. If I reboot (or powerup) with 3 or more usb devices attached to front panel, the board freezes to bios post.
What follows is from Intel Active Management Console:
SPS FW Health reports SPS Health event type FW status. Internal error during firmware execution. Image shall be updated to other version or hardware board repair is needed if the error is persistent. Status Code is 69.
Before OS Installation, I flashed BIOS from uefi, present bios version is: S1200BT.86B.02.00.0041
Prior to reissue a BIOS recovery, I would like to hear your opinions.
Many Thanks,
A.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I downgraded to previous BIOS, but same problem stands.
Also, I launched Intel Platform Confidence Test from EFI shell, and it was completed successfully.
Someone can tell me what "Satus Code 69" is? No references found into manual...
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks for your reply.
It is a Seasonic X-460. Scarcely you'll find a better psu in desktop range. It worked 3 months with another mainboard with no issues.
Also I installed a pcie 1x USB addon card, with 4 ports. If I connect any usb device to this card, avoiding mainboard native usb ports, the system is rock solid (although the message persists)...
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I don't know much about those PSU, but basing on I've read, it should be OK.
What kind of devices you are connecting to USB ports?
Where you are seeing the "status code" message?
S.V.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks again for your support.
I connected printers, plotters, and wifi plugs for some keyboards and mouses. No power-hungry usb devices.
I got (and still getting) cited message from Intel Active System Console for windows.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
As I understand, the problem occurs when you are using USB sockets from chassis which are connected to outstanding pins from motherboard.
Does it also occur when you plug devices to the rear USB sockets on motherboard?
off topic: could you give me a model of your RAM modules?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Unfortunately, the problems affects internal as well as rear usb connectors. I connected to a rear port even a self-powered usb hub, but again, if I plug more than a pair of devices in the hub, things begin to go bad.
My ram: 4 x kingston KVR13E9/8I (Intel certified).
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
OK, let's assume for now that it is only software issue.
PART I - get rid of all USB devices
1) Allow Remote Desktop access to machine,
I understand that you are using USB keyboard and mice, but we need to deal without them, that's why you must login to Windows via Remote Desktop,
2) Power down machine,
3) Unplug all USB devices while machine is off,
4) Disconnect all USB devices,
5) Power on machine,
6) Login via Remote Desktop.
PART II - remove all USB devices from system
1) Download the following tool: http://www.nirsoft.net/utils/usbdeview-x64.zip http://www.nirsoft.net/utils/usbdeview-x64.zip
2) Run above tool with Administrative privileges,
3) Find all USB devices that you can recognize - keyboards, mice, plotters, even USB sticks, right click on them and delete each,
4) Close the program.
PART III - do real driver update
(real, because in normal setup.exe-double-click you will not update all drivers, because setup program incorrectly assumes that update'ing some drivers is not neccessary)
1) Download the newest chipset drivers for your MB from http://downloadmirror.intel.com/20928/eng/intel_chipset_v9.3.0.1025_whql.zip Intel's Download Center (click this link),
2) Unzip downloaded file,
3) Run Command Prompt (cmd.exe) with Administrative privileges,
4) In Command Prompt, go to folder where drivers were extracted (using 'cd' command),
5) Invoke the following command: setup.exe -overall -overide
6) Installation wizard will appear, install as usual,
7) Reboot machine.
PART IV - reconnect devices
1) Connect first device,
2) Wait for graceful installation,
3) Validate for some time if the device is working properly,
4) Connect second device and do the same as above,
5) Connect third device and do the same as above,
... and so on.
I wish you luck and I'm looking foward for your results!
Saelic Vogel
PS Thank you for providing me RAM model - I'm using the same in new servers and was unable to find other brands to consider. I really like Kingston, but I was dissapointed that those modules are based on ELPIDA chips. Some time ago it was Hynix, maybe ELPIDA is OK now, I don't know, there were my first chips based on it. But nevermind, I've tested them really hard and no error occured, speed is also very satisfactory.
And I have replied you about checking ECC availability here:
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks for you detailed reply. Before trying it, however, I gotta say a thing: USB problems were present even *before* OS installation. If you plug in enough usb deviced, the mobo hangs at bios POST.
Also, I booted with various linux live distros: same usb problems as for windows.
The ram: It is true that ELPIDA is considered a bit "low-end". If you want Hynix chips consider Crucial ecc ram sticks.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I understand that you are using the newest version of firmware. Have you tried complete BIOS reset (I mean: using jumper on motherboard)?
I also assume, that USB devices are not faulty, cables and sockets are OK and you've tried with other devices with the same results?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
All usb devices work fine on others workstations, with same cables.
However, I did not try complete bios reset via jumper, having fear of messing things even worse. If I'll reset bios via jumper, it will be brought to factory version?
Thanks!
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Yes, you can do this safely, without any worry.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Sorry to hear that
Please attach settings from BIOS -> Advanced -> USB Configuration.
This may sound unrelated, but set in BIOS following options:
Advanced -> PCI Configuration
Dual Monitor Video: DISABLED
Wake on LAN (PME): DISABLED
Onboard NIC1 ROM: DISABLED
Onboard NIC2 ROM: DISABLED
...the same for rest NIC ROMs
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Here my usb configuration:
http://imageshack.us/photo/my-images/526/20130506154328.jpg/ http://imageshack.us/photo/my-images/526/20130506154328.jpg/
Here platform confidence test:
http://imageshack.us/photo/my-images/829/79562718.jpg/ http://imageshack.us/photo/my-images/829/79562718.jpg/
Other bios settings you suggested, were done. But why you suggested to disable NIC roms? How this can affect USB?
Thanks!
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Try to disable USB Legacy support, but I don't think that it would help.
I would think that it could be a problem with high current load or voltage drop, but you are saying that on another computer it works fine...
About ROM: in first revisions of this motherboard (S1200BTL) there was a problem with installing Windows while NIC ROM was Enabled - you received BSOD. It was quickly corrected by BIOS update. Another thing is that when you enable NIC ROM it includes itself to bootup procedure, so if we assume that there are still some bugs or other nuances we don't know about, it was good idea to do this as precaution, that's why you were asked to to this.
For now I don't have any other ideas, but I will think about it and will reply soon.
Saelic
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Do you have USB boot priority set to disable?
First quess one of your USB device reports "memory" and the system is trying to treat it as a HDD or Floppy assigning it to the top of teh boot order. I have even seen a couple Keyboards with internal features that do this.
