5212 Discussions
S1200SP firmware upgrade path
SilverNodashi
Is there a firmware upgrade path for the S1200P motherboards?
We got some servers with the following firmware installed:
BMC FW Build Time :	2017-02-17 12:03:43
BIOS ID :	S1200SP.86B.03.01.0014.022720170201
BMC FW Rev :	1.07.10481
Boot FW Rev :	1.05
SDR Package Version :	SDR Package 0.20
Mgmt Engine (ME) FW Rev :	04.01.03.021
I would like to upgrade the BIOS and BMC firmware, but the firmware numbers on the downloads page is rather confusion, and not sequential:
Which version should I install next?
Or can I just install the latest version, 03.01.0049 ?
SergioS_Intel
Hello SilverNodashi,
Thank you for contacting Intel Customer Support.
Depending on your current BIOS version, we do recommend upgrading to a previous version before updating to the latest version. For example Prior to update your system to BIOS version 03.01.0038 or later, is required to update the system to bridge BIOS version 03.01.2032.
Having said this, can you please provide us the exact model of your serverboard so we can provide you with the proper BIOS update recommendations?
We will be looking forward to your response.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
SilverNodashi
Hi Sergio,
This is what I see in the BMC Web console:
Boot FW Rev :	1.05
Baseboard Serial Number :	QSSA72305702
and from the commandline:
C:\Users\Administrator>wmic baseboard get product,Manufacturer,version,serialnumber
Manufacturer Product SerialNumber Version
Intel Corporation S1200SP QSSA72305702 H57534-250
SergioS_Intel
We appreciate the additional details, based on the additional information you have an Intel® Server Board S1200SPOR.
You can try upgrading to version 03.01.2032 then update to version 03.01.0038 and finally to the latest version.
You can find all the available BIOS version here:
https://downloadcenter.intel.com/product/97952/Intel-Server-Board-S1200SPOR
In case you need more assistance please contact us back.
Sergio S.
SilverNodashi
Hi Sergio,
This is the sticker on the motherboard, is it still the S12000POR as you suggest? ?
SergioS_Intel
Correct, based on the PBA number of your system: H57534-250, you have an Intel® Server Board S1200SPOR.
You can confirm this information by checking the Product Change Notification file attached.
Sergio S.
SergioS_Intel
We are following your case and we would like to know if you were able to perform the BIOS update for your Intel® Server Board S1200SPOR.
Sergio S.
SergioS_Intel
We are following your case in regard to your Intel® Server Board S1200SPOR and we would like to know if you need further assistance. Remember you can try upgrading from versions 03.01.1029, the version 03.01.2028; then BIOS to version 03.01.2032 [Bridge]  then update to version 03.01.0038 and finally to the latest version.
Sergio S.
SergioS_Intel
We are following your case and we would like to know if you were able to perform the BIOS update on your Intel® Server Board S1200SPOR. Additionally, we would like to provide you with a help video on how to perform a BIOS update on your server board:
https://www.intel.com/content/www/us/en/support/articles/000032841/server-products.html
You can get the previous versions here:
Finally, you can get the latest BIOS version here:
https://downloadcenter.intel.com/download/29682/Intel-Server-Board-S1200SP-BIOS-and-Firmware-Update-for-Intel-One-Boot-Flash-Update-Intel-OFU-Utility-and-WinPE-
We will be looking forward to your updates.
Sergio S.
SergioS_Intel
We are following up on a case that is still open with on what is the proper path to upgrade the Bios for the Intel® Server Board S1200SPOR, we know that this is important for you to get it resolved and it is also equally important for us to get you the right solution. Since we have not seen an update for several days, the case will automatically close after 2 business days. You can still re-open the case by creating a new thread.
Please note that if the case is re-opened more than 15 days after closure, a new case will be created with a reference to the original case.
Sergio S.
